Total Members: 16533
Latest: Lou
New This Month: 21
New This Week: 6
Total Topics: 16562
Most Online Today: 89
Guests: 30
Total: 30
Weird LOR1602 issue, Please help!
Started by Sinferno, October 05, 2020, 03:26:05 PM
Sinferno
Maybe someone who knows FPP and coding better then me can help me understand this one......
I used this same set up last year without issue.
I have 4 LOR1602W boxes and a LOR 16ch low voltage controller all running off a Pi 3B+ with the usb LOR dongle.
Now FPP can't seem to control box #1 set to any address, however it controls all other ch's perfectly.... Here is the strange part, the box functions perfectly when i try running it from LOR software.
It seems the box is seeing a network connection and passing data, just seems FPP is not telling the first 16 chs to work.
Anyone got any thoughts? cause i have tried every way i can think of to troubleshoot this, short of changing out the box or board as that is where the Pi is mounted and i don't want to have to customize another one lol.
Is it the DC controller or one of the 1602 controllers?  I assume that when you are controlling from FPP, I assume you are controlling it using DMX.  When you are testing it from LOR, are you testing it with LOR protocol commands or DMX?
I am going to speculate that it is not happy running DMX.  Look in the manual (available on the LOR website as a download if you can't find yours) for factory reset.  That can cure a lot of "controller got confused" issues.
Sinferno
First it's one of my 1602's.... better yet its any box set to address 01
I am running LOR protocol with both FPP and LOR software
I have updated firmware even (same version)
As far as i can tell its a FPP issue so here is that info too
Version 4.1
Boxes are consecutive 1 thru 5
below is my ch output settings in FPP;
1 LOR network start ch1 end ch80 port ttyusb0 speed at 19200 and first controller set at 1
OK, that is interesting.  Work around would be to change the sequencing to use a different ID.  If there is an issue within FPP I can't help on that - I only use FPP to drive matrix panels.
Sinferno
Yeah I figured i could program around it, just figured i would see if someone had run in to the issue.
Sinferno
So it got weirder.......
I changed my channel layout to have 16 blank ch's to skip the first box issue and changer box id's to match, and then hit play.... BAM lights up!!!!!
When i go into test mode and go ch by ch the first 16 ch's should be blank..... they are not!
In test mode what is wired and programmed to be ch 17 turns on when you turn on ch 1.
Does this make sense to anyone? or is it just me?
Sinferno
Problem solved! FPP was outputting LOR thru a usb connection starting at #2, This was fixed in todays release.
K2-Pi0 Unable to Start FPPD by JonD
Today at 08:34:57 PM
PWM for GPIO control by tbone321
Today at 11:23:29 AM
Can Falcon Player support WPA3? by JonD
Today at 05:05:28 AM
Falcon PiCap v2 failed upon upgrade to FPP v8 by darylc
September 17, 2024, 10:00:13 PM
MIDI input from Apple Mainstage by jjung
September 17, 2024, 10:19:20 AM
So in Xlights what RGB in string settings do I use to get the colors correct by tbone321
September 17, 2024, 09:58:14 AM
FPP V8 Plugins Needing Testing by deanathpc
September 17, 2024, 08:54:45 AM
Varying Effects for Groups of Submodels by k6ccc
September 17, 2024, 07:40:04 AM
Raspberry pi 4 issues by JonD
September 17, 2024, 05:43:46 AM
What am I missing - FPP 8 artnet input configuration by mrcorbu
September 16, 2024, 10:22:19 PM
