Total Members: 15659
Latest: PaulDzRGB
New This Month: 9
New This Week: 3
Total Topics: 15791
Most Online Today: 68
Members: 3
Guests: 27
Total: 30
Test button not working
Started by Red Rock, November 12, 2020, 10:24:51 AM
Red Rock
Hi Everyone
I have a smart receiver where the test button doesn't work. I didn't it was big deal but I trying to output to my lights and that is not working either.
I have tried connecting it to both my PB-8 and B-8. I have put it in normal mode and smart receiver A mode, I changed the cat 5 cable and change the port. The fuse and power led are lit and I have power to the lights. I double checked (make that triple checked my wiring) and it is good. When I run a sequence the data leds do not flash.
The BBB string in FPP is set to smart receiver.
Any other ideas?
rjm12rjm12
I'm having similar issues with my smart receiver boards.  I'm connecting to a F4V3, one of my two boards outputs data on port 1, but the other don't do anything.  My test button does not work and the four LEDS are all off.  I posted in another topic, I saw the manual say the board needs 5.3v - 13v.  I am supplying 5v, I was afraid to up it, not sure it my LEDS would be OK.
Well good luck to you, if I hear anything I'll let you know.
Rob
Brutane
I know it's an old post but did you ever find any solution to this?  Having similar issues when trying to fire mine up this year.
I have seen some female dongles come from factory miss wired.  In fact my 2 wire power injection cables have to be wired backwards (black on positive and red on negative) to work correctly.   Make sure positive and negative is correct to the board, make sure power supply is set to 110v instead of 220v, make sure you did not wire female dongle on backwards.
Attaching a photo of the board, power supply wiring, dongle wiring might help.
F16V3 with 2 expansion boards at 40 fps MAX PIXELS per output? by tbone321
Today at 10:51:55 AM
F48V4-NS at 40 fps using all 48 pixel output ports? by Poporacer
Today at 10:27:09 AM
Unable to update RPi 5.5 to latest version by JonB256
February 05, 2023, 07:23:16 PM
help getting started, next step? by rayster
February 05, 2023, 04:24:09 PM
Warning/Error: Network incomplete frames hit 250. by darylc
February 05, 2023, 04:06:58 PM
F48v4NS - Pi or No Pi? by joeyblasko
February 05, 2023, 09:15:33 AM
Huidu Controllers LED matrix by CaptainMurdoch
February 04, 2023, 10:18:47 AM
FPP6.2 universes by darylc
February 03, 2023, 08:48:57 PM
F16v4 Ports vs Universe Configuration Question by k6ccc
February 03, 2023, 09:32:48 AM
Need Expert Advise on F16v4 Ports vs Universe Configuration by Kairus
February 03, 2023, 09:32:33 AM
