Total Members: 16950
Latest: izpele
New This Month: 3
New This Week: 3
Total Topics: 17027
Most Online Today: 106
Guests: 70
Total: 70
FPP 4.5 Released!
Started by dkulp, November 23, 2020, 12:27:33 PM
firstlightautomation.com
Hey I am new to the FPP world. I am installing it on a Raspberry Pi 3B, and it comes up with FPP login: what do I put there.
Quote from: firstlightautomation.com on December 02, 2020, 09:07:43 AMHey I am new to the FPP world. I am installing it on a Raspberry Pi 3B, and it comes up with FPP login: what do I put there.
Nothing! It sounds like you connected a monitor to your Pi? If so, a monitor is almost useless. You access everything through a web interface. There are step by step instructions in the FPP Manual here: https://falconchristmas.github.io/FPP_Manual(4.3).pdf and a Step by Step video here:
pixelpuppy
Like Rick said, a directly connected monitor is not needed. Go to your PC, open a web browser (Chrome is preferred) and enter  http://fpp.local/ to access the FPP user interface
If that doesn't work, you'll need to find the IP address of your FPP.  Since you obviously did connect a monitor, look for where it says "My IP address is: x.x.x.x
Then enter the IP address of your FPP in the web browser.
PRH
#18
Evening,
First timer here.
I have Falcon Player 4.5 installed on my PI. I have a monitor connected to the pi to watch the boot process. At the end it says my ip address is 196.168.8.1. I followed the instructions in the FPP manual and attempt to connect wireless. I keep getting no internet message. I clicked on network properties and the IPv4 has an ip of 196.168.8.2. I have not been able to connect to the PI to set up fpp. I am running windows 10  Any ideas?
Thanks PRH
Salt Lake City
NEVER MIND MY STUPID
Quote from: PRH on December 03, 2020, 10:42:33 PMI have a monitor connected to the pi to watch the boot process. At the end it says my ip address is 196.168.8.1. I followed the instructions in the FPP manual and attempt to connect wireless.
I am confused because the Manual says nothing about connecting a monitor. But, if you are attempting to connect using the Wi-Fi Tethering method, did you log into the FPP network? How are you trying to access your FPP device? fpp.local? What model Pi?
pixelpuppy
Quote from: PRH on December 03, 2020, 10:42:33 PMI followed the instructions in the FPP manual and attempt to connect wireless. I keep getting no internet message.
That is normal at this stage of setup.  FPP doesn't have "Internet" access yet.  It only has a connection between itself and your PC.
Quote from: PRHI clicked on network properties and the IPv4 has an ip of 196.168.8.2.
that's what you want.  Completely normal at this stage of setup when using the WiFi tethering method
Quote from: PRHI have not been able to connect to the PI to set up fpp. I am running windows 10  Any ideas?
HOW are you trying to connect?  If you're following the instructions for WIFI TETHERING then you need to point your web browser to 192.168.8.1
You can not use the http://fpp.local/ method when using WiFi or USB tethering.  That is for later when FPP is up and running on your home network
Santacarl
I'm confused (as usual...haha)...I see instructions on how to upgrade if you're already running an older image....How do you do an install on a completely new and fresh Pi that has never been set up?
Thanks...
Quote from: Santacarl on December 06, 2020, 02:15:08 PMI'm confused (as usual...haha)...I see instructions on how to upgrade if you're already running an older image....How do you do an install on a completely new and fresh Pi that has never been set up?
You read the second line in the first post in this thread.
Santacarl
Quote from: k6ccc on December 06, 2020, 02:30:18 PM
Thanks for the response...  would that be the line starting with "In-place upgrade"?  If so I was reading that and ran into this sentence "Download the appropriate "fppos" file to your computer."
Being less than fluent in this area I had no clue what the "appropriate file" is... Duh on me...Sorry to be so clueless but I don't understand this enough to know intuitively.... Would that be the fppos for 4.5 or the one for the older OS that has to be loaded first?
Thanks...I appreciate the patience necessary to coach my non-technical fumbling...  ;)
Quote from: Santacarl on December 06, 2020, 03:01:25 PMwould that be the line starting with "In-place upgrade"?
Yes, that would be it
Quote from: Santacarl on December 06, 2020, 03:01:25 PMBeing less than fluent in this area I had no clue what the "appropriate file"
No worries, this is something fairly new
Quote from: Santacarl on December 06, 2020, 03:01:25 PMWould that be the fppos for 4.5 or the one for the older OS that has to be loaded first?
No, you download the fppos for the version that you are upgrading to so in this case you would download either BBB-v4.5.fppos or Pi-v4.5.fppos depending on your FPP device
Quote from: Santacarl on December 06, 2020, 03:01:25 PMThanks...I appreciate the patience necessary to coach my non-technical fumbling
No worries!
Santacarl
Quote from: Poporacer on December 06, 2020, 03:08:02 PM
No worries!
Thank you for the clarification....I'm sort of a read a step, do a step, get a banana type guy.....at least until I've done it enough times to understand what I'm doing....I don't 'intuit' very well.  Math teachers used to drive me nuts when they'd skip 2 or 3 steps ahead in a calculation and do in their head what was intuitively obvious to them but would leave me scratching my head and lost in the dust...Haha....
Santacarl
One last question....what is the "FPP instance" referring to in the in-place upgrade instruction?  Also...these instructions don't refer to the  FPP-v4.5-Pi.img.zip file....is that not used when you load the "fppos" file?
bigwavedave
The zip file is used if you're doing a fresh reimage from scratch.  The fppos file is only used for in-place upgrades.
I suspect they say "FPP Instance", since it could be a BeagleBone, Pocket Beaglebone, Raspberry Pi, Container, etc etc etc.  Just making it a generic reference :)
nmiller0113
Quote from: Santacarl on December 06, 2020, 03:16:39 PMOne last question....what is the "FPP instance" referring to in the in-place upgrade instruction?  Also...these instructions don't refer to the  FPP-v4.5-Pi.img.zip file....is that not used when you load the "fppos" file?
@Santacarl a FPP Instance is anything that is running FPP. The in-place upgrade is only if you have FPP FPP 3.6.2 (or 4.0-alpha2) or newer already running. The very end of that original post references the initial install image files, like the FPP-v4.5-Pi.img.zip you stated, and you choose based on your hardware, either the BBB or Pi (standard or kiosk).
Santacarl
Quote from: nmiller0113 on December 06, 2020, 04:11:32 PM
Thanks for the response....Got it up and running now that I got some help...  I always hesitate just to plunge in to something if I don't understand what I'm trying to accomplish....I've fried too many things doing that...Haha....
But I still didn't use the FPP-v4.5-Pi.img.zip file.....Did I not complete the install...?  Seems to be running....
Help with migration to new controller by dkulp
June 02, 2025, 06:49:46 AM
Abnormal conditions, received bridging data while sequence is running by Paulanator
June 01, 2025, 05:07:39 PM
CycleRandomSequences by seaton road xmas lights
June 01, 2025, 03:30:58 AM
Can't connect through FPP Proxy by Poporacer
May 29, 2025, 12:28:05 PM
Is it possible to either output multiple overlay lines on LED Matrix? by bobbond000
May 28, 2025, 09:51:53 AM
Something changed when using FPP Connect by andywylde
May 27, 2025, 09:22:56 PM
PiCap V2 - newbie questions by jnealand
May 27, 2025, 07:17:39 AM
Can't get past Initial Setup by ukkeef
May 26, 2025, 12:25:02 PM
FPP 8.4 released! by Santacarl
May 22, 2025, 01:24:42 PM
possible interference: Solved by darylc
May 17, 2025, 10:28:48 PM
