Total Members: 16534
Latest: theatretch85
New This Month: 22
New This Week: 7
Total Topics: 16564
Most Online Today: 94
Guests: 25
Total: 26
Wifi does not connect using the 2.59 firmware
Started by ybjr38@yahoo.com, July 12, 2021, 01:41:37 PM
ybjr38@yahoo.com
I updated my F4V3 controller trying to take advantage of the remote ability of the controller.  I went into the status and set it to remote and hit set.  I then went to the network page and set up the controller like I would when using an FPP to run the controller in remote mode.  All settings were set as static IP. I went to the last tab and set that to wireless. I was able to ping the controller through wireless using the cmd prompt.  I was not able to ping it through the FPP master.
Settings.
Wired
  192.168.1.52
192.168.1.1
255.255.255.0
Wireless
192.168.149
192.168.1.1  I tried the 2.1 but that went nowhere either.  Also tried setting it to 0.0.0 like I would for an fpp no difference
255.255.255.0
I can run the light test when it is wired but not in wireless
I would really like to be able to use the wireless remote function to eliminate having to use an fpp to run it remotely since it has that function.
I only see the wireless chip upper light during powerup and never again but do see the lower red light on the chip  I know the upper is just indicating data is running.
What am I doing wrong?
pixelpuppy
You are going to have issues if you put both the wired and wireless on the same subnet (192.168.1.x in this case).
Is the Master using wired or wireless?  And what are the IP addresses (eth0 and wlan0) of your FPP Master?
ybjr38@yahoo.com
I used the 192.168.1.1 for the wired network.  I have attached a picture of how my master FPP is hooked up.  I have included both the ETHO and ETH1. The fpp is wireless.  I have no issues with any of the controllers I have that are set up to run as remotes.  I am trying not to have to continue to buy FPP to do remote as it is just more money when the controller should work as a remote as I have said.  I know there has to be something that I am not doing correctly but have no idea what it is.
I double-checked to make sure the controller was set up in the output controllers on the FPP and even set it in the Proxy setting.  I also made sure it used the FPP mater was set correctly in the Controller and the IP address was correct.
I atached a image of the Controller setup in xlights also.
Pause (and manually resume) after each playlist item by Poporacer
Today at 09:41:40 AM
PWM for GPIO control by tbone321
Today at 09:32:33 AM
K2-Pi0 Unable to Start FPPD by JonD
Today at 03:14:49 AM
New K16s by tetleytealeaf
September 18, 2024, 10:04:29 PM
Can Falcon Player support WPA3? by JonD
September 18, 2024, 05:05:28 AM
Falcon PiCap v2 failed upon upgrade to FPP v8 by darylc
September 17, 2024, 10:00:13 PM
MIDI input from Apple Mainstage by jjung
September 17, 2024, 10:19:20 AM
So in Xlights what RGB in string settings do I use to get the colors correct by tbone321
September 17, 2024, 09:58:14 AM
FPP V8 Plugins Needing Testing by deanathpc
September 17, 2024, 08:54:45 AM
Varying Effects for Groups of Submodels by k6ccc
September 17, 2024, 07:40:04 AM
