Total Members: 15733
Latest: aquila2heman
New This Month: 15
Total Topics: 15885
Most Online Today: 107
Guests: 83
Total: 83
K8-PB No network on first run
Started by blackramair, September 26, 2021, 11:21:21 AM
blackramair
Have a new K8-PB I just put together for my neighbor, I plug in my usb hub with ethernet from my F8-B and fire it up. The board boots and displays no network it's like the USB port is getting power or something. Did I miss a step since it has been a couple years since I last setup a new Kulp board? Thought maybe it was a power issue to I switched out the wire to 12ga from PSU to K8-PB board but that didn't change anything.
UPDATE:
I was able to isolate it to the cape. I can use a micro usb cable and boot the pocket beagle and connect to FPP.  Seems like the USB on the cape isn't getting powered up.
rharrington76
Quote from: blackramair on September 26, 2021, 11:21:21 AMHave a new K8-PB I just put together for my neighbor, I plug in my usb hub with ethernet from my F8-B and fire it up. The board boots and displays no network it's like the USB port is getting power or something. Did I miss a step since it has been a couple years since I last setup a new Kulp board? Thought maybe it was a power issue to I switched out the wire to 12ga from PSU to K8-PB board but that didn't change anything.
UPDATE:
I have isolated this on two Capes this year.  Have 4 of the 40PBs.  Not sure if it is the hubs causing the component fail, but also have the F8-B and have had no issues with those.  Sure would be nice to know what is causing this failure on multiple boards and if there is a resolution.  never tethered and used the same USB hub and wifi adapter as I am using on the ones that work.
technowolfe
I'm having the same issue with a couple of new K40D-PB's.  I believe that I have also isolated the issue to the K40D boards (not the PB).  One of my K40's will connect via eth0 as expected, but when I plug in the recommended USB wireless antenna, it knocks the entire network offline on the controller and I have to unplug the wireless and reboot.  On my second K40D, I can't get the eth0 network to register at all.  Really at a loss as to what to try next.  The USB hub, wireless antenna and network cable all perform perfectly when hooked into my spare K8-B.
@dkulp , Is there's a process for sending in my boards for further analysis and repair if necessary?
Sound Reactive in Real Time by MikeKrebs
May 28, 2023, 09:15:58 PM
colorlight 5a-75b not working with raspberry pi4B fpp by JonB256
May 28, 2023, 03:17:40 PM
Lack of communication from supplier by darylc
May 26, 2023, 11:13:11 AM
DIY BBB CAPE by shanebou24
May 26, 2023, 08:56:42 AM
Fpp and xlights preview not working by breese
May 26, 2023, 04:16:17 AM
K4-PB Wifi setup confusion by mikeh565
May 25, 2023, 09:27:21 AM
How to connect a button (via GPIO) to a K16A-B by k6ccc
May 24, 2023, 08:01:36 AM
Logic Shift a 12v Data Pin to Control 5v WS2812b with Optocoupler by MikeKrebs
May 22, 2023, 10:32:33 PM
V7 Alpha shell not working by MikeKrebs
May 22, 2023, 10:04:06 PM
K8-Pi Cape Power by VistaLeaf
May 22, 2023, 10:24:13 AM
