Total Members: 15463
Latest: Lwarnell01
New This Month: 86
New This Week: 4
New Today: 4
Total Topics: 15537
Most Online Today: 90
Members: 4
Guests: 61
Total: 65
Sequencing traditional led light strings
Started by haydenjensen1111, October 11, 2021, 03:38:31 PM
haydenjensen1111
New to the forum and looking for some help from some more experienced members.
I have a raspberry pi b+ connected to two 8 channel relays through the GPIO pins that control outlets and turn on and off my traditional led Christmas lights. I have the all of the hardware set up and have ran through all 16 of my channels on the display testing tab on FPP and everything works as intended. I am having issues creating me sequences in xLights however. I have created 16 models and set them all as single color string types. My timing is set at 500ms and each model is only on a single channel. When i then try to run the .fseq file in FPP the relays randomly activate super quickly for a few seconds and then stop. I have searched all over but its pretty difficult to find people using the relay/dumb lights set up.
Edit: I should also note that i had a made a sequence 3 years ago (havent used xLights since) that worked just fine and still works. I only have the .fseq file for it saved though so i cannot go back into xlights to see how i did it.
Any advice would be greatly appreciated,
Hayden
jem5136
I would suggest updating the sequence. First make sure you have the current version of FPP and xLights installed. You'll be able to open the fseq file in xlights and it'll open as a regular sequence. From there you can edit and save it as an xsq file. Render and save the sequence (which will update the fseq file). And run the updated fseq file on the Pi and see what happens.
braveit1
Have you checked the output options for your sequence?  Do you save it as v2 uncompressed?
What is the second best way to get rid of pixel gap errors? by JonD
Today at 06:26:47 AM
Today at 12:12:07 AM
show locks me out of falcon player by rudybuddy
November 26, 2022, 07:16:32 PM
Daisy Chain PSU by schbrownie
November 26, 2022, 07:00:52 PM
