Total Members: 16529
Latest: garrettw27
New This Month: 17
Total Topics: 16558
Most Online Today: 87
Guests: 48
Total: 50
xLights, LOR, DMX Bridge, and Lynx Express!
Started by Donny M. Carter, October 28, 2014, 06:44:09 PM
Donny M. Carter
Need some help please! I seem to not get anything when import a LMS file in to xLIghts! I create an xLights sequence and save it. I then convert an LMS file and save, but when I output to preview or actual lights, I get no AC channels. Pixels work fine. I can go to the test tab and the lights work fine. can add a model with the corect AC channel to the xLights sequence and lights work fine. When I try it importing an LMS file, no lights! Any idea please!?
JonB256
During the conversion from LMS to XSEQ, did you check the "Map Empty LMS Channels" box?
If not, that is probably the answer. If you have a lot of LMS channels with no data, it can move things around (compact them).
Donny M. Carter
Quote from: JonB256 on October 29, 2014, 04:43:15 AM
Yes it's checked. After trying for several days. I created a simple 32 channel lms file with effects in each channel. Still no luck.
JonB256
How about a screen shot of your LOR Network Preferences and a description of your devices.
I've done at least a dozen LMS to XSEQ conversions without problem. But - my setup in LOR is 100% E1.31 output of DMX. Much cleaner.
It gets trickier (and out of my experience) if you have USB/COM Port outputs.
Donny M. Carter
Quote from: JonB256 on October 29, 2014, 08:32:03 AM
Attached are pics of everything, I hope! Thanks for your help! :)
[attachment deleted by admin]
Donny M. Carter
I decided to remove all hardware and start from scratch. I hooked up a single Lynx Express to my laptop using a Lynx dongle. I then converted a LMS file in xLights and still no go! I go to test in xLights and the controller works! If I add a LOR model in xlights and add an effect, hit save and go to preview. The lights work! WTH!?!
Donny M. Carter
Lights are blinking. Ended up being a undefined channel at the beginning of the LOR sequence! Thanks to everyone for the help!
FPP V8 Plugins Needing Testing by ShadowLight8
Today at 08:07:31 PM
Raspberry pi 4 issues by dspenman
Today at 07:23:34 PM
So in Xlights what RGB in string settings do I use to get the colors correct by tbone321
Today at 06:08:59 PM
K2-Pi0 no output to pixels by ironsniof
Today at 02:30:33 PM
Varying Effects for Groups of Submodels by JonD
Today at 01:14:56 PM
K2-Pi0 Unable to Start FPPD by darylc
Today at 12:45:13 AM
Control lights directly from the GPIO of a PI by Poporacer
September 15, 2024, 12:25:42 PM
New K16s by dkulp
September 15, 2024, 08:23:40 AM
FPP After Hours Music Plugin has been updated by jcross
September 14, 2024, 08:49:51 PM
Intermittent Test Pattern failure on Channel Outputs > LED Panel by k6ccc
September 14, 2024, 08:11:30 PM
