Total Members: 15463
Latest: Lwarnell01
New This Month: 86
New This Week: 4
New Today: 4
Total Topics: 15536
Most Online Today: 71
Guests: 62
Total: 64
Raspberry PI direct connect LED Pixel to GPIO 18?
Started by CyberMicha, December 21, 2021, 01:04:50 PM
CyberMicha
Hi all,
i´ve read that it is possible to connect a pixel sting direct to the gpio 18 on the raspberry pi.
Is that wrong? I've tried it but the pixel stay dark when i start the sequenz.
See attached an image of the wiring an settings.
How do i have to setup xlights and flacon player? is there a tutorial for the actual version of falcon player?
kind regards
Michael
CyberMicha
Maybe i have to power up the voltage of the gpio 18? Using 12v Pixel but dont know the needed voltage of the data channel.
pixelpuppy
Quote from: CyberMicha on December 21, 2021, 02:24:03 PMUsing 12v Pixel but dont know the needed voltage of the data channel.
12v pixels use the same 5v data logic as 5v pixels.  Internally they're all 5v pixels.  The 12v pixel have voltage dropping resistors or a voltage regulator to drop the 12v supply voltage down to 5v into the ws2811 chip.   The data is the same for both.
Hard to tell from your picture but make sure you run Data AND Gnd from the GPIO's to the pixel.  Don't run just a data wire by itself.   It looks like you may have it wired right, but hard to see for sure.
More likely its not fully configured in the FPP software.  Post a screenshot of your FPP Channel Outputs -> Pixel Strings page so we can tell you if that's configured properly or not
CyberMicha
#3
Hi Mark.
Thanks for your reply. I will post a Screenshot from fpp later.
The gpio 18 uses only 3.3v as far as i know. Problem?
An here´s the Screenshot of fpp
pixelpuppy
Yeah, the GPIO is only 3.3v, but its not a problem as long as the distance to the first pixel is fairly close.
Looking at your screenshot shows the "Enable String Cape" check box is not enabled.  That's why nothing lights up.  You need to check that box and SAVE
CyberMicha
Quote from: pixelpuppy on December 22, 2021, 06:10:56 AMYeah, the GPIO is only 3.3v, but its not a problem as long as the distance to the first pixel is fairly close.
But i have no Cape? I will try later.
I got an answer from the seller of the string an he said that the 3.3v are under the minimun. Should be at least 4.5V.
Quote from: CyberMicha on December 22, 2021, 09:04:49 AMBut i have no Cape? I will try later.
Enabling the Cape is what sends the outputs to the GPIO pins, The capes are connected to those pins, so the cape has to be enabled to tell FPP to send the data to the GPIO pins.
CyberMicha
So it is for now. Tomorrow i receive the logic level converter 3,3v to 5v. Hope it will work then. Don´t want to buy a expensive controller before i tried to control ws2811 pixel leds.
In xlights i will go for port 1 and 2.
pixelpuppy
Quote from: CyberMicha on December 22, 2021, 09:04:49 AMhe said that the 3.3v are under the minimun. Should be at least 4.5V.
It works.  Lots of people do it.  Especially with wearables like the hats you see with small scrolling pixel matrix.  I do it with a few Pi Zeros and pixels connected directly to the GPIO pins.
CyberMicha
It´s dont working :(  I ve tested the voltage at gpio 18. It´s between 0.03 and 0.08v direkt at the gpio when i run a sequence.
What can i do :(
I think the output just dont work correctly.
CyberMicha
Again my Settings.
Maybe someone can post his settings with direct connected ws2811 leds?
Quote from: CyberMicha on December 23, 2021, 12:22:54 PMI ve tested the voltage at gpio 18. It´s between 0.03 and 0.08v direkt at the gpio when i run a sequence.
You can't test the Data with a multimeter, the Data is a fluctuation signal that goes from 0 to 3.3v and a multimeter will average the voltage, even on full white, the data signal is still going from 0 to 3.3V! The only real way to see the signal is with an oscilloscope.
Quote from: CyberMicha on December 23, 2021, 12:29:02 PMAgain my Settings.
Well, you do not have any pixels configured on your outputs, so you won't get anything out! Look at your pixel count.
CyberMicha
Quote from: Poporacer on December 23, 2021, 01:26:18 PM
I also tried with 50 pixels on port 1 but nothing happens. Very frustated :/
You have some important items missing!
In xLights on your controller tab set your Vendor to FPP and Variant to Pi-Hat
Then set the Auto Layout Models and Full xLights control and Save
Then go to the Visualizer and assign the models to the ports you are using by dragging them in the correct place and exit and Save
Once you do that, then FPP Connect will work properly, make sure you put a check in the Cape option in the far right of the screen.
Quote from: CyberMicha on December 23, 2021, 01:32:12 PMI also tried with 50 pixels on port 1 but nothing happens. Very frustated
You need to start at the controller. Test from the controller, if the lights are not lighting up using the test function in the controller itself, then it is usually a wiring problem, pixels wired on the wrong end, V+, Gnd, Data not properly connected to the correct pins, cable length too far for the voltage/Data, etc.
Don't go any further if the testing from the controller isn't working first. You have to get it working there first.
Today at 12:12:07 AM
show locks me out of falcon player by rudybuddy
November 26, 2022, 07:16:32 PM
Daisy Chain PSU by schbrownie
November 26, 2022, 07:00:52 PM
Backwards string on Mega tree by schbrownie
November 26, 2022, 06:53:47 PM
