LATEST RELEASE:  FPP 5.5 - Download from here - https://github.com/FalconChristmas/fpp/releases/tag/5.5
Total Members: 15225
Latest: robj2022
New This Month: 14
Total Topics: 15136
Most Online Today: 51
Guests: 30
Total: 30
New to PiCap -
Started by techiebeckyg, June 19, 2022, 08:35:43 AM
techiebeckyg
I used FPP to run a virtual matrix last year, then ran across the PiCap and ordered a couple.  I have some LOR dumb rbg controllers for floods and windows, so having the output port seems like it would be perfect for off season lighting.
My conundrum, I cannot get anything lit up to save my life, even on pixel test mode.
I am powering the Pi and the PiCap separately.
I get white lights on output 1 and nothing on ouput2 as soon as I plug them in, but no changes in pixel test mode.
I have attached screenshots of inputs, outputs and version info.
I use xlights visualizer then upload the configuration to the Pi.  I know this has to be something stupid, and I am just not seeing it.
Help please..I was very excited to get this working and moved outside so I can get my house outline(pixels) added to my off season lighting and stop running the LOR controllers in standalone mode.
JonB256
On the PiCap (if it is a Falcon PiCap, anyway), did you move the jumpers to LOR? That's because LOR controllers expect their data on lines 4 and 5, not the DMX standard of lines 1 and 2.
Also, how old is the firmware on those controllers. The PiCap is sending DMX protocol data, not LOR protocol, so your firmware must be new enough to support auto-sense of DMX.
Quote from: techiebeckyg on June 19, 2022, 08:35:43 AMI am powering the Pi and the PiCap separately.
Are the jumpers set correctly for this? What PiCap?
Quote from: techiebeckyg on June 19, 2022, 08:35:43 AMI get white lights on output 1
Sometimes all white lights are an indicator that the pixels are wired backwards. Are you sure the correct end of the string is connected to the controller and the correct wires to the correct terminals?
Quote from: techiebeckyg on June 19, 2022, 08:35:43 AMI use xlights visualizer
The way that you have xLights configured, the visualizer will not really do much. you need to set the Auto Configure models and Auto size
I may be missing something but what type of pixels are you using?
techiebeckyg
@JonB256 - it is a Falcon PiCap, the jumpers are set to LOR.  I am not trying to connect to the LOR controllers yet, just get some pixels lit direct off the PiCap for now.
@Poporacer  - The jumpers are set or powering them separately, I will triple check the wiring, but I even went back and pulled up the diagrams for the pigtail and the PiCap to make sure I was putting things together correctly.  Originally they were not, and I wasn't even getting white lights.
I will Set Auto Configure and Auto size and see what changes.
@tbone321 - I have a strip of 12v WS2811 from wallys lights on one connection and C7 WS2811 pixel bulbs from the same place on the other.
Touchscreen by breese
Today at 05:14:16 AM
Powering Falcon PiCap for DMX use only by danielr
August 13, 2022, 11:24:40 PM
Tester or oscilloscope on the data line?? by johndobbs
August 13, 2022, 10:39:12 PM
F8-B Cap and GPIO Pins by dkulp
August 13, 2022, 11:47:45 AM
PiCap Slow DMX output? by robj2022
August 13, 2022, 11:42:27 AM
Historical knowledge needed - Falcon Differential Remotes by algerdes
August 12, 2022, 09:47:34 PM
Issues with e-mail by CaptainMurdoch
August 12, 2022, 09:42:57 PM
Programmatic interface to make interactive messages/signs on LED Panel with FPP? by CaptainMurdoch
August 12, 2022, 10:38:50 AM
FPP v6.0 on separate subnet by jnealand
August 12, 2022, 09:22:09 AM
BBB Display by TracyDockter
August 11, 2022, 05:18:12 PM
