Total Members: 15513
Latest: jonbuddy
New This Month: 21
New This Week: 9
New Today: 8
Total Topics: 15614
Most Online Today: 72
Members: 4
Guests: 44
Total: 48
FPP 6 upgrade process feedback.
Started by jnealand, July 13, 2022, 11:46:53 AM
dennismccreery
Tried upgrading from FPP 5.4 to 6.1, OS upgrade went okay, but now FPPD won't start.  Here's what the logs show, any idea what could be wrong?
fpp@FPPMain:~$ systemctl status fppd.service
× fppd.service - FPPd
     Loaded: loaded (/lib/systemd/system/fppd.service; enabled; preset: enabled)
     Active: failed (Result: signal) since Thu 2022-09-22 19:23:07 PDT; 2min 29s ago
   Duration: 4.264s
    Process: 18943 ExecStartPre=/opt/fpp/scripts/fppd_boot_pre (code=exited, status=0/SUCCESS)
    Process: 18969 ExecStart=/opt/fpp/src/fppd -f (code=killed, signal=ABRT)
    Process: 18970 ExecStartPost=/opt/fpp/scripts/fppd_boot_post (code=exited, status=0/SUCCESS)
   Main PID: 18969 (code=killed, signal=ABRT)
        CPU: 4.251s
Sep 22 19:23:07 FPPMain systemd[1]: fppd.service: Scheduled restart job, restart counter is at 5.
Sep 22 19:23:07 FPPMain systemd[1]: Stopped FPPd.
Sep 22 19:23:07 FPPMain systemd[1]: fppd.service: Consumed 4.251s CPU time.
Sep 22 19:23:07 FPPMain systemd[1]: fppd.service: Start request repeated too quickly.
Sep 22 19:23:07 FPPMain systemd[1]: fppd.service: Failed with result 'signal'.
Sep 22 19:23:07 FPPMain systemd[1]: Failed to start FPPd.
fpp@FPPMain:~$ journalctl -xeu fppd.service
░░ Subject: Unit process exited
░░ Defined-By: systemd
░░ Support: https://www.debian.org/support
░░ An ExecStart= process belonging to unit fppd.service has exited.
░░ The process' exit code is 'killed' and its exit status is 6.
░░ Subject: Unit failed
░░ The unit fppd.service has entered the 'failed' state with result 'signal'.
░░ Subject: Resources consumed by unit runtime
░░ The unit fppd.service completed and consumed the indicated resources.
░░ Subject: Automatic restarting of a unit has been scheduled
░░ Automatic restarting of the unit fppd.service has been scheduled, as the result for
░░ the configured Restart= setting for the unit.
░░ Subject: A stop job for unit fppd.service has finished
░░ A stop job for unit fppd.service has finished.
░░ The job identifier is 1284 and the job result is done.
░░ Subject: A start job for unit fppd.service has failed
░░ A start job for unit fppd.service has finished with a failure.
░░ The job identifier is 1284 and the job result is failed.
Quote from: dennismccreery on September 22, 2022, 08:31:04 PMTried upgrading from FPP 5.4 to 6.1, OS upgrade went okay
I hate to say this but did you see this?
Quote from: dennismccreery on September 22, 2022, 08:31:04 PMany idea what could be wrong?
See above... To use the fppos upgrade, you have to upgrade to the most current version of FPP 5.5 first.
Sometimes applying the fppos 6.1 upgrade a second time will fix the problem.
dennismccreery
Thanks, I had upgraded from 5.4 to 5.5 before I made the leap to 6.1.  I think I got it working, turns out that
I'm using an HE123 Cape, which had a blank EEPROM.  I had to get an EEPROM image from here:
https://apps.mortonlights.com/he123-unsigned/
Thanks to Alan Hanson for that!  Once the EEPROM was loaded, I signed it with a 48 port key that I got from shop.falconplayer.com.
A couple of reboots later and it appears to be running, FPPD now runs.  Would have been nice to have a clear message
about what was wrong, but oh well!
Regards,
Dennis the Menace
