Total Members: 15481
Latest: nicholas.buckler
New This Month: 103
New This Week: 17
New Today: 7
Total Topics: 15565
Most Online Today: 105
Guests: 55
Total: 55
Beaglebone Green Wireless half working on FPP 5.5
Started by Sarah.Dods, July 14, 2022, 04:53:16 AM
Sarah.Dods
Please can I ask for help - I'm not sure whether I've hit a known bug, or done something stupid.
I've got FPP running on an RGB48 revision F cape (Alan Hanson's HE123Mk2).  The SBC is a Beaglebone Green wireless.  I've just read in the FPP manual (page 8)  that "the Beaglebone Green Wireless can't be used with capes."  Does anyone know what not, or what the error behaviour is?
I've got data coming out of ports 1, 2, 9 and 10 on the 16 channel main board (so the first 2 in each set of 8).  I've got an expansion running to channels 33-36, and of those, channels 33 & 34 work (again first 2), and the other 2 don't.
Does that align with whatever the known incompatibility is, or is this something different?  Has anyone seen it before, and any ideas on how to fix it?
Thank you for any words of wisdom that could be provided.  And yes, I have to have a wireless for this controller - it's about where it is and actually my whole setup runs distributed on wifi - the rest is on pi zero W's, and works like a charm.
#1
Quote from: Sarah.Dods on July 14, 2022, 04:53:16 AMDoes anyone know what not, or what the error behaviour is?
Some of the output pins are used for the Wi-Fi processing.
Quote from: Sarah.Dods on July 14, 2022, 04:53:16 AMDoes that align with whatever the known incompatibility is,
It sounds like it.
Quote from: Sarah.Dods on July 14, 2022, 04:53:16 AMHas anyone seen it before, and any ideas on how to fix it?
Sadly, it is don't use the BBGW
Quote from: Sarah.Dods on July 14, 2022, 04:53:16 AMAnd yes, I have to have a wireless for this controller - it's about where it is and actually my whole setup runs distributed on wifi
You can use a Wi-Fi dongle on a Beagle Bone Black or a BeagleBone Green (of course not on the BBGW). And it works great, I have 6 controllers all on Wi-fi using those dongles.
The WIFI adapter on the Green Wireless consumes 13 of the GPIO pins.   Those are 13 pins that can no longer be used for pixels.  Thus, it's likely that 13 of the HE123Mk2 ports won't be usable.
The best option is to use a BBB and a USB wifi adapter.  The Wifi on the BBGW is also fairly slow at around 10Mb/s.  Using a USB adapter will definitely provide higher speeds.   You can disable the onboard WIFI by commenting out the enable-wireless line in /boot/uEnv.txt to re-gain the pins, but then you obviously need some sort of USB network adapter.
AAH
Thanks for sharing the info Dan. Can you tell me which of the IO's are gobbled up by the wifi. I've been googling and so far I haven't been able to work out which of the IO's get used on the wifi. I'd like to add that info to my brain and also document in my HE123 manual.
On P8, pins 11, 12, 14, 15, 16, 17, 18, and 26.   On P9, pins 12, 28, 29, 30, 31.   I have a ? in my notes for P9-41 so I'm not really sure if that one is available or not.
Sarah.Dods
Hi all,
Thanks for your help.  Now I understand the problem, I've been able to do some quantitative testing to understand what's possible.  For the HE123, attached is the output channel table of what works, for 32 of the 48 possible channels.  Have found 9 unusable pixel ports.  The last 4 unusable ports will be in the 17-32 channel range somewhere.  There's enough ports working that I'll be able to get it to meet my needs, which is great.  The ports that can't be used for data are still useful as fused power injection sources.
Also, saw the comment on wifi being slow.  To test, put it side by side with another controller running a Pi Zero W (these are what I run the rest of my display from).  Attached is also these results.  122 is the BBGW, 129 is PiZeroW.  I think that will also be OK.  If there's other tests people would like me to run, let me know.
Your spreadsheet matches what I came up with.  There are only 2 outputs between 17-32 that conflict and those are outputs 28-29.  There are 2 pins of the 13 Dan mentioned which are not used by the HE123-Mk2 which uses the RGBCape48F pinout.  The 2 unused are P8-11 and P9-41 so only 11 conflict.
The full list of conflicts is outputs:
3-7, 28-29, 35-38, and 42.
I'm not sure why output 37 on P9-30 worked for you for pixels, I don't know what it is used for on the BBGW.
I have a HE123-Mk2 and was working on putting together a HE123-Mk2 EEPROM image.  I considered including a 'BBGW w/ WiFi' config option which would skip these 11 pins that conflict with WiFi.  This way you wouldn't even be able to use them for pixels and FPP wouldn't configure them so WiFi should continue to work.
Is a plugin approach suitable for GPU/framebuffer IO? by Cureck
November 28, 2022, 11:33:06 PM
FPP 6.x Matrix Issues by Poporacer
November 28, 2022, 08:32:23 PM
f48 and new differential receivers by yarhoward
November 28, 2022, 08:27:31 PM
RGBW on PiCap by EricD
November 28, 2022, 07:37:58 PM
DIY voucher request by scottn3xcc
November 28, 2022, 07:02:15 PM
Stuck on initial startup screen by haydenjensen1111
November 28, 2022, 07:01:11 PM
Wiring Diagram for the RJ45 port for DMX by K-State Fan
November 28, 2022, 06:49:08 PM
Uploading Models to FPP Remote by rudybuddy
November 28, 2022, 06:44:04 PM
Receiver Issues and Freezing up by rudybuddy
November 28, 2022, 06:31:24 PM
Kulp K8 with receiver - having issues with receiver freezing by rudybuddy
November 28, 2022, 06:22:29 PM
