Total Members: 15699
Latest: Nicole4Z
New This Month: 17
Total Topics: 15831
Most Online Today: 53
Members: 3
Guests: 33
Total: 36
API over serial?
Started by jsamytaylor, July 21, 2022, 07:55:31 AM
jsamytaylor
Ist there a way to send API commands over a serial port on a Beaglebone Controller?
I would like to make a Userinterface with an M5Stack Core2 (ESP32 based Board with Display). My Goal is to make a Userinterface where I can select Playlist to start..stop and so on. To send the commands I would use a serial port. Would be nice if there is a way to send API commands over serial communication. Maybe it is necessary to write a plugin or script?
Thanks for any answers!
At this point, it would require a plugin.   It wouldn't be very hard to write and could easily be done in python or c++ or something.   If the UI can generate the JSON for the command, it could send that via serial and the plugin/script could just forward it directly via curl.
That said, the ESP32 has wifi built in.  Why use serial instead of over the network using the REST API?
jsamytaylor
Hi Daniel
I appreciate your fast reply! I used the REST API over Network before which worked very good. In this case I have a Standalone controller without Network connection. I know I could use GPIO inputs, but that would require more wiring and the flexibility is not good as controlling FPP over the API.
My Userinterface could send a JSON String over the serial port. I am not very good in coding. So writing a plugin or script is not my capability.
Could you help me out or do you know someone who could do it for me? I am also willing to pay for the effort.
I think you should be able to do this using "socat" and emulating a HTTP client on your ESP32, but it has been a while since I have messed with it.
Try the following:
sudo apg-get install -y socat
socat /dev/ttyS0,b115200,raw,echo=0 TCP:127.0.0.1:80
Change /dev/ttyS0 the proper device for the serial port and the 115200 speed to the correct value.  socat should create a two-way pipe between your serial port and the web server running on port 80.  From there, you can send HTTP requests over serial.  You might need to add ",keepalive" to the end of the TCP string.  If it works, you can create a script to run it inside a while loop in case socat dies.
#!/bin/sh
while /bin/true
do
done
Flexible ws2811 panels by Mark_M
March 29, 2023, 09:39:37 PM
March 28, 2023, 11:03:41 PM
March 28, 2023, 03:18:46 PM
March 28, 2023, 09:28:23 AM
March 27, 2023, 07:54:22 AM
March 24, 2023, 04:04:06 PM
March 24, 2023, 10:44:49 AM
March 23, 2023, 11:06:14 AM
March 22, 2023, 11:11:59 AM
March 21, 2023, 05:53:50 PM
