Total Members: 15472
Latest: Moores351
New This Month: 94
New This Week: 9
New Today: 8
Total Topics: 15549
Most Online Today: 67
Guests: 49
Total: 51
4-String Differential SmartReceiver v2.01 Board
Started by breese, August 02, 2022, 09:20:27 AM
HuskerInTexas53
Correct, I am not using any expansion boards.  I don't think it makes any difference, but I have just one receiver path plugged in for now (17, 18, 19, 20).
All lights work when I use the receiver test button.
HuskerInTexas53
Found it!!  Bad cable between my F16V4 and smart receiver.  Swapped it out with new cable, and everything is working!
Sorry for the bother but thank you so much for checking.  If nothing else, it made me groom and triple-check my entire system.
#17
Quote from: HuskerInTexas53 on September 14, 2022, 07:58:40 PMI don't think it makes any difference, but I have just one receiver path plugged in for now (17, 18, 19, 20).
If they are in zero mode (Normal Mode/Native Mode) the port numbers would be 17,18,19, and 20.  If they are in Smart Receiver A mode the port numbers would be 17a,18a,19a, and 20a.  If they are in Smart Receiver B mode the port numbers would be 17b,18b,19b, and 20b.  The last device in any chain, needs to be terminated.  Termination basically absorbs the remaining energy in the wire, preventing it from turning around and going back (Reflection).  If the data tries to return and head backwards, it can cause ghosting and other undesired results.
If you are plugging the second Smart Receiver into controller port (RCVR2)... both Smart Receivers should be placed in A mode, and both should be terminated as they are the only device in the chain.  The one plugged into RCVR1 port would be ports 17a,18a,19a, and 20a  The second plugged into RCVR2 would be ports 21a,22a,23a, and 24a.
The onboard RCVR1 and RCVR2 port numbers will vary depending how many expansion boards you installed.  For example, if you are using one expansion board, RCVR1 will be assigned ports 33,34,35, and 36, instead of 17,18,19, and 20.
Glad it was just a bad cable.
Unable to get DHCP after FPP install by Jlwright325
November 27, 2022, 11:31:30 PM
What is the second best way to get rid of pixel gap errors? by k6ccc
November 27, 2022, 10:32:34 PM
FPP connect by LedMutt
November 27, 2022, 09:29:34 PM
FPP Scheduler duplicate by Aaron Maue
November 27, 2022, 09:24:20 PM
Audio Stalls on 8th music sequence by JonD
November 27, 2022, 08:09:16 PM
F48 with Daisy Chained Smart Receivers by JonD
November 27, 2022, 07:55:30 PM
Kulp 32A-B setup by tgeorges
November 27, 2022, 05:54:31 PM
MultiSync copying of Show Files not working in FPP 6.1.1 by jnealand
November 27, 2022, 05:27:32 PM
November 27, 2022, 05:18:57 PM
show locks me out of falcon player by torn8o
November 27, 2022, 05:09:31 PM
