Total Members: 15463
Latest: Lwarnell01
New This Month: 86
New This Week: 4
New Today: 4
Total Topics: 15537
Most Online Today: 90
Guests: 56
Total: 58
BBB Display
Started by TracyDockter, August 09, 2022, 04:01:19 PM
TracyDockter
My K16A-B is not displaying in info on the OLED. It was working a few weeks ago. I tested all 16 ports. I've reseated the SD Card and also reloaded the SD card with FPP 6.0.2. I can access FPP via browser just fine and upload controller configs from within xlights. No display on the OLED.....I'm not sure how to troubleshoot any further.  Any  assistance would be very much appreciated.
Quote from: dock24_1@hotmail.com on August 09, 2022, 04:01:19 PMNo display on the OLED.....I'm not sure how to troubleshoot any further.
How about a screenshot of your FPP Settings page....It will look something like this:
TracyDockter
Thanks-Mine does look the same.  See Attached
TracyDockter
The controller worked when I first received it back in June.  It's been sitting with no power in the box until I just tried it again a few days ago. There hasn't been any config changes, so I'm at a loss! I have a feeling it maybe faulty, but don't have any idea how to get assistance to determine that. Any additional advice is greatly appreciated.
Can you go to the Troubleshooting Commands page under the main Help menu and click the 'i2cdetect' link and past the contents of that section here so we can see if the OLED is being detected by the OS?
TracyDockter
This is what it shows:
Loading...
TracyDockter
Then finally this:
Failed to query command:
Error: Unable to query for i2cdetect
Quote from: TracyDockter on August 11, 2022, 05:18:12 PMThen finally this:
I'm not sure why you are getting this error, but we should be able to get the same info from the logs zip.  Can you go to the FPP File Manager and the Logs tab and download the logs zip and attach it here.  Also, as another test, I believe the OLED is detachable on the cape.  Can you try powering the system off, removing the OLED, and powering on, and seeing if the same i2cdetect error shows in the Troubleshooting page in the UI.  Do any other sections of that page also display a similar query error or is it only i2cdetect?
TracyDockter
I have reseated the OLED, but that didn't change anything. I'm looking how to upload the zip file.  I'm not seeing that as an option when I reply to this message.
Quote from: TracyDockter on August 17, 2022, 06:44:29 PMI'm looking how to upload the zip file.  I'm not seeing that as an option when I reply to this message.
Quick Reply doesn't give you the option to attach files. You have to go to the preview screen before you can add attachments.
TracyDockter
The i2cdetect output in the logs zip is empty, so it means the OLED is not being detected for some reason.  Can you try powering off, removing the OLED, and rebooting without the OLED installed?  I see some errors in the messages log file like this:
Mar 20 15:12:11 FPP kernel: [ 1025.007584] omap_i2c 4819c000.i2c: timeout waiting for bus ready
Also, the i2cdetect output in the logs zip isn't showing anything.
Title  : i2cdetect
Command: sudo i2cdetect -y -r 2
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
00:                         -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
We should see at least something in the output like this:
root@rpi18:~# i2cdetect -y -r 1
30: -- -- -- -- -- -- -- -- -- -- -- -- 3c -- -- --
50: UU -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- UU -- -- -- -- -- -- --
After you reboot without the OLED installed, view the 'messages' file in the File Manager Logs tab.  If the 'waiting for bus ready' entries are not shown, then shutdown and reinstall the OLED and boot again and check the log again.
TracyDockter
I'm still seeing: (without the OLED)
20 14:55:34 FPP kernel: [  12.179136] omap_i2c 4819c000.i2c: timeout waiting for bus ready
Mar 20 14:55:34 FPP kernel: [  13.181126] omap_i2c 4819c000.i2c: timeout waiting for bus ready
Mar 20 14:55:34 FPP kernel: [  13.183275] at24 2-0056: supply vcc not found, using dummy regulator
Mar 20 14:55:34 FPP kernel: [  14.185133] omap_i2c 4819c000.i2c: timeout waiting for bus ready
Mar 20 14:55:34 FPP kernel: [  15.187127] omap_i2c 4819c000.i2c: timeout waiting for bus ready
Something's definitely wrong with the i2c bus.   My first instinct would be to remove the BBB and then re-attach it to make sure the connections are clean and solid and see if that helps.   Also make sure the P9 header to the BBB is clean.
TracyDockter
OK sure thing! I've removed the BBB several times.  When this issue first started I removed it to reload the SD card. I'll try again this evening and let you know.  Thanks for you help.
What is the second best way to get rid of pixel gap errors? by JonD
Today at 06:26:47 AM
Today at 12:12:07 AM
show locks me out of falcon player by rudybuddy
November 26, 2022, 07:16:32 PM
Daisy Chain PSU by schbrownie
November 26, 2022, 07:00:52 PM
