Total Members: 15502
Latest: UpSyD0wN
New This Month: 10
New This Week: 38
New Today: 3
Total Topics: 15597
Most Online Today: 72
Members: 6
Guests: 55
Total: 61
PiCap Slow DMX output?
Started by robj2022, August 13, 2022, 11:42:27 AM
robj2022
Falcon PiCap to DMX is very slow output.
Testing with a Falcon V4 works great. PiCap doesn't.  I'm using the same cables in both setups, no wifi involved.
xlights on PC, Output to Lights -> Falcon V4->DMX pixel changes instantly
xlights on PC, Output to Lights -> Falcon PiCap->DMX pixel changes after about 2-3 seconds.
PiCap running on a Raspberry Pi3, FPP version 6.0.2-8-g8bc1f372FPP in Player mode
Channel input enabled, 1 input active, E131, unicast, FPP Channel start 1, end 510, universe 1, universe count 1, universe size 510
Channel outputs: other, active DMX-Open, start channel 1, Chanel count 16, Desc blank, Port ttyAMA0
PiCap works, sending the right pixel color, it just is tremendously slow to update, and rapid changes are lost in the time lag.Am I in a wrong mode or missing an important step?
Do the DMX pixels change properly when you run a sequence?  I believe that xLights changes some settings in FPP when you turn on (or off) Output to Lights, so that could be what is causing the delay.
Are you saying pixels are always delayed when xLights is sending through FPP out the DMX port?  There should not be any delay.  I would also use the Channel Tester page in FPP to see how quickly the DMX pixels respond when you change the settings on the test page.  There will be a slight lag as the new test data is setup, but it isn't anywhere near 2-3 seconds.
JerryPlak
something to try..
on the FPP setting add the check mark to the "Always transmit channel data"
to see if helps
Jerry Plak
bloojoop
If it is just when you start the test, make sure "Auto upload configuration" is NOT checked.  That is the setting that Chris was referring to just above.  It is generally recommended not to have that setting checked.
--Ron A.
Sequence freeze by jnealand
Today at 02:51:04 PM
Raspberry PI 4 won't connect to WIFI by jnealand
Today at 02:46:23 PM
new piCaps in the works? by jnealand
Today at 02:38:26 PM
Today at 01:04:54 PM
Today at 12:04:54 PM
Beagle Bone Black for sale by ppanelli3
Today at 10:40:18 AM
Port 11 not working by rossg10
Today at 09:57:03 AM
Remote script issue by mac1321
Today at 06:43:26 AM
December 02, 2022, 11:15:17 PM
Bacground sequence by darylc
December 02, 2022, 07:34:21 PM
