Total Members: 16521
Latest: Vet4Christ
New This Month: 9
Total Topics: 16545
Most Online Today: 87
Members: 3
Guests: 34
Total: 37
No signs of life, help
Started by projectortoph, September 23, 2022, 11:18:17 AM
projectortoph
Hi everyone,
I have a F48 v1.01 that runs my whole light show. It has been powered off since January until yesterday when I tried powering it on and got nothing, no OLED and no power LED. I verified my 5v power is working but still nothing. The F48 is mounted in a CG-1500 box on the wall of my garage year around but it is not powered. Any ideas for troubleshooting? Thank you.
Per manual "A 5V with a 3A minimum is required to power the controller. Use either the barrel connector OR the V2 Power Connector to power the board, NOT BOTH. This power supply only powers the controller, it does not provide any power to the pixels themselves. "
Assuming you have tried another outlet, and not something as simple as GCFI that has tripped.  You can make sure the power wires did not corrode from humidly or short out somewhere,  If your not getting any signs of life, sounds like the board could have went bad.
fauxton
Did you verify that the 5/12v switch or jumper is in place?  I'm not familiar with each version but I know most of them have it.
I am building pixel interface capes for BBB - http://www.ledpixeldriver.com
projectortoph
Thanks for the reply JonD. I have verified power and tried a brand-new Meanwell 5v 60A power supply. I'm only talking about the F48 board.
fauxton, the F48 controller only accepts 5v.
Quote from: projectortoph on September 23, 2022, 01:47:36 PMI have verified power and tried a brand-new Meanwell 5v 60A power supply.
The older smart receivers require 5.3 volts to run.  If you are using a meanwell power supply, you might crank up the volts to 5.3 and see if anything lights up.  If not turn it back down to 5.0.  If that was the issue, it would have probably showed itself last year though.
projectortoph
Thanks JonD, but the problem isn't with the receivers and the Meanwell power supply is outputing 5.3V.
I have emailed David Pitts and went through some basic troubleshooting but ultimately I will be sending it to him to look at.
The F48 manual stated 5v minimum, but it was for an older board revision.  You mentioned 5v, so if you were at 5.0, I thought there might a long shot that 5.3 might get you over the hump.  Some of the new smart receivers require 5.3 volts and was not sure if the newer F48 version did as well.  Glad your getting to the bottom of it.
Can I control 12 volt WS2811 Pixels with the PI Hat. by kryptic
Today at 07:43:35 AM
Falcon srx1 psu problem by Vet4Christ
Today at 04:34:56 AM
Setting up FPP and Xlights to talk to PCA9685 (Servos) by tbone321
September 09, 2024, 09:14:43 PM
HELP - Panels Blown or PocketScroller messed up by DaSarge
September 09, 2024, 05:03:25 PM
P5 Matrix on FPP 8.0 help by k6ccc
September 09, 2024, 08:07:19 AM
Lights don't work on K16 by jnealand
September 09, 2024, 07:23:53 AM
New K16s by dkulp
September 08, 2024, 06:07:48 PM
LED Panel issue after upgrade to v8 by k6ccc
September 06, 2024, 05:54:33 PM
Leave eth0 Gateway blank by colonelcline
September 06, 2024, 09:19:53 AM
FPP After Hours Music Plugin has been updated by ckuhner
September 06, 2024, 07:58:54 AM
