Total Members: 15699
Latest: Nicole4Z
New This Month: 17
Total Topics: 15830
Most Online Today: 44
Guests: 20
Total: 21
FPP Settings dropdowns not populating
Started by jacksonho, November 29, 2022, 07:01:50 AM
jacksonho
Hi all,
I am running into issues with some of the FPP settings drop downs not populating. Some are working but some are not, for example In can't see the below
Audio Output Device
Default Video Output Device
RTC
TimeZone
Apache logs seem to indicate an error, any idea how to solve this? It is throwing my config off because I can't select a time server for example
[Tue Nov 29 13:57:39.352548 2022] [php7:warn] [pid 1151] [client 192.168.0.19:54471] PHP Warning:  file_get_contents(http://127.0.0.1/api/settings/AudioOutput/options): failed to open stream: HTTP request failed! HTTP/1.1 401 Unauthorized\r\n in /opt/fpp/www/common.php on line 428, referer: http://192.168.0.198/settings.php
[Tue Nov 29 13:57:39.373596 2022] [php7:warn] [pid 1151] [client 192.168.0.19:54471] PHP Warning:  array_keys() expects parameter 1 to be array, null given in /opt/fpp/www/common.php on line 430, referer: http://192.168.0.198/settings.php
[Tue Nov 29 13:57:39.373749 2022] [php7:warn] [pid 1151] [client 192.168.0.19:54471] PHP Warning:  count(): Parameter must be an array or an object that implements Countable in /opt/fpp/www/common.php on line 430, referer: http://192.168.0.198/settings.php
[Tue Nov 29 13:57:39.415933 2022] [php7:warn] [pid 1160] [client 192.168.0.19:54536] PHP Warning:  file_get_contents(http://127.0.0.1/api/settings/TimeZone/options): failed to open stream: HTTP request failed! HTTP/1.1 401 Unauthorized\r\n in /opt/fpp/www/common.php on line 428, referer: http://192.168.0.198/settings.php
[Tue Nov 29 13:57:39.416294 2022] [php7:warn] [pid 1160] [client 192.168.0.19:54536] PHP Warning:  array_keys() expects parameter 1 to be array, null given in /opt/fpp/www/common.php on line 430, referer: http://192.168.0.198/settings.php
[Tue Nov 29 13:57:39.416377 2022] [php7:warn] [pid 1160] [client 192.168.0.19:54536] PHP Warning:  count(): Parameter must be an array or an object that implements Countable in /opt/fpp/www/common.php on line 430, referer: http://192.168.0.198/settings.php
jacksonho
No matter, I sorted it myself. I disabled the UI password and it worked.
What version of FPP.  This was fixed in 6.1.
jacksonho
Hi, I was originally on 6.0 but upgraded to 6.2 via the web interface. It was still an issue until I took away the UI password option. I re-enabled it just then and now it works fine. Perhaps it was a carry over issue from 6.0 and needed to be checked on and off to fix it?
Quote from: jacksonho on November 29, 2022, 03:20:26 PMI re-enabled it just then and now it works fine
Is there a specific reason you are even enabling the UI Password? That is typically not the preferred method. This does not provide you any type of security and is similar to putting a lock on your fridge in case someone breaks into your house.
March 28, 2023, 11:03:41 PM
March 28, 2023, 03:18:46 PM
March 28, 2023, 09:28:23 AM
March 27, 2023, 07:54:22 AM
March 24, 2023, 04:04:06 PM
March 24, 2023, 10:44:49 AM
March 23, 2023, 11:06:14 AM
March 22, 2023, 11:11:59 AM
March 21, 2023, 05:53:50 PM
March 21, 2023, 09:37:23 AM
