Total Members: 15699
Latest: Nicole4Z
New This Month: 17
Total Topics: 15831
Most Online Today: 44
Members: 4
Guests: 37
Total: 41
XLights Variant
Started by poucedeleon, December 05, 2022, 02:04:58 PM
poucedeleon
I am relatively new to Xlights.  I am trying to troubleshoot an issue that I think is keeping me from using "FPP Connect" to send my sequences to my KULP controller. I hope someone on the forum can help me select the correct Variant in xlights. I have a Beaglebone Black, with a Kulp K8-B Cape. I also added a Falcon 4 String Smart Differential Receiver Board v2.01 (Black). This all works fine when my computer is plugged into the eth port of the BBB and Xlights is running. I am going through all my settings trying to eliminate possible issues.
Kulp Lighting K8-B, BBB, FPP (5.5), HolidayCoro Smart pixels C9
You need to select "K8-B", not "F8-B".
poucedeleon
Daniel, That is what was causing the error message. The wife kept saying you're just overlooking something, I'm sure it will be simple! haha. I am now able to send my sequence to the controller and it works as long as I add the pixel output info each time. This is what it looks like before I use FPP Connect,
and then after
For some reason, it deletes ports 2 and 3. At least I can now run the show from my controller.
Thank you very much.
Quote from: poucedeleon on December 06, 2022, 03:31:44 PMFor some reason, it deletes ports 2 and 3.
Can you post a screenshot of your Controller page in xLights and then the visualizer page?
It looks like you have not configured ports for those 2 strings.  XLights will still assign channel numbers to them even if they are not assigned to a port or controller and include them in the sequence files but FPP Connect uses the controller definitions from the layout and if you didn't define a controller or assign props to specific ports on that controller, FPP Connect will not include them when configuring the controller and will remove any settings in the controller that it doesn't know about.  Go into the layout page in XLights and take a look at those 2 strings definitions under controller.  It will probably say none.  You can click on the controller def box and assign them to your controller and the port that they are connected to and don't forget to save after you make the changes and then the next time you use FPP Connect, it will include those strings when it configures the controller.
poucedeleon
#5
I forgot about the visualizer. Again I am pretty new with Xlights, but I remember someone telling me a few years ago to move the ports to the right. I have not made any changes at this point. I would like to get some feedback from the forum.
Visualizer
Garage Outline_Layout Page
Garage Door_Layout Page
K-State Fan
Move them to the ports they are suppose to be on.  With them not assigned you are telling xLights you are not using them and then xLights is setting your controller to match
poucedeleon
Life is good!!!! That fixed it, now I am able to upload sequences, with no issues. I want to thank you all for your help.
Flexible ws2811 panels by mrfix1
Today at 03:57:26 PM
March 28, 2023, 11:03:41 PM
March 28, 2023, 03:18:46 PM
March 28, 2023, 09:28:23 AM
March 27, 2023, 07:54:22 AM
March 24, 2023, 04:04:06 PM
March 24, 2023, 10:44:49 AM
March 23, 2023, 11:06:14 AM
March 22, 2023, 11:11:59 AM
March 21, 2023, 05:53:50 PM
