Total Members: 15733
Latest: aquila2heman
New This Month: 15
Total Topics: 15885
Most Online Today: 107
Guests: 92
Total: 92
Which volume to grow during setup?
Started by RickR, January 25, 2023, 09:45:08 AM
RickR
Hi all,
Newbie here.  I need to know which volume on the sd card to expand.  This appears to be linked to my inability to save the Initial Setup.  I can change it all day long but it doesn't get saved. This has been a real time waster.
Rick
That doesn't look right.  It looks like the card was not formatted correctly to begin with.  What size is that card?  I would start over with it.  Use SD Formater and make sure that every partition is removed and you are starting with a clean clear card.  Also make sure that Windows doesn't try and "fix" it after the image is copied to it and you are about to remove the card from the PC because that at times has Windows create a second partition.
That is only showing that you are attempting to use what looks like a 4gb card.  You need at least an 8gb card.  I buy 32gb these days because they are easier to find and the price difference is minimal.
RickR
Gentlemen,
Thanks for your reply.  In reality, it is a 32GB card.  I will look for a SD formatter that runs on my mac. Any suggestions?
RickR
Ah, the Disk Utility gets the job done.  Starting over.
K-State Fan
Quote from: RickR on January 25, 2023, 08:00:34 PMGentlemen,
https://www.sdcard.org/downloads/formatter/sd-memory-card-formatter-for-mac-download/
Just click the "Grow Filesystem" button on the bottom.   It can only grow the last one and that's exactly what it will do.
RickR
Hi Dan, thanks very much. I have completed this project now. FPP is working great! Just a quick question with respect to different RPi boards.  Can I use the same disk image on Rpi 4b and Zero 2W?
IMHO The easiest way to get the zeros going is to build the image on a fullsize pi and then move the card.  Done that many times.
RickR
Excellent!  Thank you for your responses!  I am looking forward to plug and play RPi / FPP!
bloojoop
For the record, Pi images have 2 partitions, a /boot partition (p1) and a root partition (p2).  The initial image is around 4gb which is why it looked like this in the original posting.  When you select "grow file system", it will grow the last partition p2 to the full size of the card.  Using SD card formatter is NOT required as the image burning process does a full overwrite anyway.
--Ron A.
Sound Reactive in Real Time by MikeKrebs
May 28, 2023, 09:15:58 PM
colorlight 5a-75b not working with raspberry pi4B fpp by JonB256
May 28, 2023, 03:17:40 PM
Lack of communication from supplier by darylc
May 26, 2023, 11:13:11 AM
DIY BBB CAPE by shanebou24
May 26, 2023, 08:56:42 AM
Fpp and xlights preview not working by breese
May 26, 2023, 04:16:17 AM
K4-PB Wifi setup confusion by mikeh565
May 25, 2023, 09:27:21 AM
How to connect a button (via GPIO) to a K16A-B by k6ccc
May 24, 2023, 08:01:36 AM
Logic Shift a 12v Data Pin to Control 5v WS2812b with Optocoupler by MikeKrebs
May 22, 2023, 10:32:33 PM
V7 Alpha shell not working by MikeKrebs
May 22, 2023, 10:04:06 PM
K8-Pi Cape Power by VistaLeaf
May 22, 2023, 10:24:13 AM
