Total Members: 15733
Latest: aquila2heman
New This Month: 15
Total Topics: 15885
Most Online Today: 107
Guests: 70
Total: 70
Attempting to move to FPP 6.3 from 4.4 - Assigned IP is in different subnet.
Started by twseeman, January 30, 2023, 03:25:36 PM
twseeman
Having issues moving to 6.3 FPP from 4.4.  Using Raspberry Pi image.  when I boot with the 6.3 image, no IP is assigned to eth0.  wlan0 does get assigned 192.168.8.1.  when I compare to bootup with 4.4 image, wlan0  is 192.168.0.98.  That one in reachable from the local network and I can bring up FPP.  On the 6.3 FFP bootup, the 192.168.8.1 is unreachable.
I am using a Cox Panoramic modem/router.  I think that router is forcing the Pi to bootup in the alternative subnet and it is not reachable.  Any suggestion / documentation on a solution would be greatly appreciated.
Tom
Make sure that your Pi's Ethernet port is plugged into your router during bootup.  Do you have a monitor hooked up to the Pi when booting it up?  Wlan0 is not getting that address from the router.  That is a default address FPP gives it when there are no other connections.  Until FPP is configured, it has no way to connect to your WIFI because it does not know the SSID or Password of your WIFI network.
Quote from: twseeman on January 30, 2023, 03:25:36 PMwhen I boot with the 6.3 image, no IP is assigned to eth0.
Is this a fresh install or an upgrade. How are you determining that there is no IP assigned to eth0? If FPP is not connected to your network, it won't get an IP.
Quote from: twseeman on January 30, 2023, 03:25:36 PMwhen I compare to bootup with 4.4 image,
How are you comparing these IP addresses? Where are you looking to see them?
Quote from: twseeman on January 30, 2023, 03:25:36 PMwlan0  is 192.168.0.98
About the only way that will happen is if you manually configured your wlan0 settings. A new image will require you to manually enter your settings.
Quote from: twseeman on January 30, 2023, 03:25:36 PMOn the 6.3 FFP bootup, the 192.168.8.1 is unreachable.
How are you trying to reach it? If you are simply entering that IP address in your browser, it won't work. you have to log into the FPP network first.
Quote from: twseeman on January 30, 2023, 03:25:36 PMI think that router is forcing the Pi to bootup in the alternative subnet and it is not reachable.
That is highly unlikely....
Quote from: twseeman on January 30, 2023, 03:25:36 PMAny suggestion / documentation on a solution would be greatly appreciated.
The FPP Manual has step by step instructions and here is a video on 5.5 but the process is almost identical except that on the initial set up page, you have to enter your choice if you want to set a UI password (not recommended to set one) and if you want to change the OS password (recommend to keep the default)
Here is a link to the Manual as well https://falconchristmas.github.io/FPP_Manual(6.0).pdf
colorlight 5a-75b not working with raspberry pi4B fpp by aquila2heman
Today at 02:46:12 AM
Sound Reactive in Real Time by MikeKrebs
May 28, 2023, 09:15:58 PM
Lack of communication from supplier by darylc
May 26, 2023, 11:13:11 AM
DIY BBB CAPE by shanebou24
May 26, 2023, 08:56:42 AM
Fpp and xlights preview not working by breese
May 26, 2023, 04:16:17 AM
K4-PB Wifi setup confusion by mikeh565
May 25, 2023, 09:27:21 AM
How to connect a button (via GPIO) to a K16A-B by k6ccc
May 24, 2023, 08:01:36 AM
Logic Shift a 12v Data Pin to Control 5v WS2812b with Optocoupler by MikeKrebs
May 22, 2023, 10:32:33 PM
V7 Alpha shell not working by MikeKrebs
May 22, 2023, 10:04:06 PM
K8-Pi Cape Power by VistaLeaf
May 22, 2023, 10:24:13 AM
