LATEST RELEASE:  FPP 7.0 - Download from here - https://github.com/FalconChristmas/fpp/releases/tag/7.0
Total Members: 15932
Latest: pavit66767
New This Month: 21
Total Topics: 15999
Most Online Today: 102
Guests: 53
Total: 54
K8-Pi - Random Pixels on
Started by Gilmax, March 09, 2023, 12:22:04 PM
Gilmax
I just received my Kulp Lights K8-PI, and I'm not sure where is the best place to discuss issues I am having with it, but figured this was as good as any.  This is a fresh clean install of the most recent FPPOS.  It detects the Cape just fine.  The issue I am having is that when I plug in a string of lights (tested with multiple strings and multiple ports) some (3) of the pixels light up blue.  If I go into any test mode the pixels respond correctly, and as soon as I stop the test, they return to being blue.  I tested the strings on a previous Falcon PiCap, and have no issues with them their, so the problem only exists while using the K8-PI.  What details/information do I need to provide to help with this issue?
(The pixels are 12v from DIYLEDExpress.com purchased in early December of 2022).
RS
It's on a Pi 4, correct?
As mentioned on the product page, it MUST be using master branch FPP code.   FPP 6.3 will not work, particularly on a Pi4. The DPI code was pretty much developed on a Pi3 so the timings work ok there with FPP 6.3, but on the Pi4, you definitely need the master branch updates.
Gilmax
Yes this is on a Pi4.  I will get updated to Master and retest.  Thank you.
cybercop23
Using Pi-4 on Master and all was okay until last night when I upgraded Master. Now FPPD keeps on crashing. I detached to an earlier commit (not sure if it was the one that I was using) and still have the same issue. Based on fppd log... last successful load was on FPP 7.x-master-24-g5a1aedf6; will try to go back to that.
Crash reports are configured to be sent.
cybercop23
Quote from: cybercop23 on March 24, 2023, 08:51:49 AMUsing Pi-4 on Master and all was okay until last night when I upgraded Master. Now FPPD keeps on crashing. I detached to an earlier commit (not sure if it was the one that I was using) and still have the same issue. Based on fppd log... last successful load was on FPP 7.x-master-24-g5a1aedf6; will try to go back to that.
Yup... this version works... lots of commits after.. will try to ID which one breaks
FPP Version:7.x-master-24-g5a1aedf6
cybercop23
Quote from: cybercop23 on March 24, 2023, 09:16:14 AM
@dkulp looks like 44272e26 that deals with e-fuses
Can you go to the Cape info page and the EEPROM Upgrade tab and update to the latest firmware for the K8-Pi?   I think you may have the original firmware which tried to use the eFuse stuff to work around issues in the DPI code.  That is all now fixed so it's not necessary.
cybercop23
Quote from: dkulp on March 24, 2023, 09:53:06 AMCan you go to the Cape info page and the EEPROM Upgrade tab and update to the latest firmware for the K8-Pi?  I think you may have the original firmware which tried to use the eFuse stuff to work around issues in the DPI code.  That is all now fixed so it's not necessary.
Thanks. That seems to make it work. It did originally say ver 1.0 and the upgrade was still 1.0, but after the upgrade the above branch worked and moved it back to head and still working. Thanks again.
State of falcon pi cap? by K-State Fan
Today at 05:26:05 AM
Text on Matrix by JonD
September 29, 2023, 03:01:31 PM
Is the Pi 3B still supported on 7.1? by Poporacer
September 29, 2023, 12:36:58 PM
Unable to dock sub-Windows back into xLights by cmndr brain
September 28, 2023, 09:15:00 PM
FPP Ignore GPIO triggers outside show hours by robbiet
September 28, 2023, 08:39:29 AM
Can’t see F16V3 through FPP by Laser Falcon
September 27, 2023, 03:26:16 PM
All new stuff by i1uhrace
September 26, 2023, 09:57:48 PM
Unable to change color curves by cmndr brain
September 26, 2023, 05:44:08 PM
Matrix audio issue by MikeKrebs
September 25, 2023, 09:11:08 PM
Music and models out of sync by MikeKrebs
September 25, 2023, 09:08:25 PM
