LATEST RELEASE:  FPP 7.0 - Download from here - https://github.com/FalconChristmas/fpp/releases/tag/7.0
Total Members: 15932
Latest: pavit66767
New This Month: 21
Total Topics: 15999
Most Online Today: 102
Guests: 53
Total: 53
Limitations on Video file size?
Started by Jayl, March 14, 2023, 09:00:48 AM
Jayl
My project is simple enough - unrelated to lighting and/or Christmas :)
I am setting up several video screens to run synchronized video (for an Art exhibition). My setup works flawlessly in principle, but I have a problem with the video file sizes.
I could not find a specification for the largest video file size allowed. I do know that over 2GB doesn't work, and below 1GB does.
I know I can split my video into sections, but I prefer not to do it - as this creates a small black disruption between the sections
What is the real limitation on video file size, and how to overcome it?
Thanks,
Jay
Quote from: Jayl on March 14, 2023, 09:00:48 AMWhat is the real limitation on video file size, and how to overcome it?
You posted your question in "The Lab" section and did not mention the product your asking about.
The Pi3 and Pi4 have a video resolution limit of 1080p (1920x1080) at H.264.  The Pi4 additionally supports H.265 at 4K resolution (3840x2160).  A single controller would not support that many lights at full resolution even if the Pi could.  Since whatever your doing works at 1gb and not 2gb, could this be a resolution difference instead of file size problem?
darylc
You may find that the limit is on the upload side into ftp, try uploading using winscp or scp or similar rather than fpp connect or the fpp web interface and see if larger files work ok.
Jayl
Thanks for the responses!
I already tried to transfer a 2.35GB video via scp to the media/videos directory with no issue, however when I open the file manager in FPP, it indicates the length of the video as "unknown", and it's impossible to add it to a playlist.
This is apparently an FPP issue, which I don't understand, and would hope it would be fixed..
Jay
darylc
what version of fpp?  There was a fix to that unknown file size thing in the master branch from memory, but this should all be unrelated to whether you can add it to a playlist or not, that part doesn't make sense to me. Maybe share some screenshots of that aspect?
Jayl
It took me a while to get to this.. Attached are 3 screenshots -
1. The terminal window into the media/videos folder, showing the large file (Evening)
2. The video in FPP, with an "Unknown" size
3. The error when trying to add it to a playlist
Jayl
forgot to add - I am using the latest FPP 6.3
darylc
Yeah try changing to master and see if it works
Jayl
Hi - thanks.
There are only two options (I know of): Player & Remote, where the Player is the de-facto master, syncing the other RP's.
The test I did was on the Player.
Jay
darylc
Master as in the version, eg it has a lot of bugs fixed that were in 6.3
FPP Settings->UI->Developer then  FPP Settings->Developer->Git Branch (change from 6.3 to master)
Jayl
Jayl
Thanks again! I tried a 2.5GB file, and it was uploaded with no problem.
(I am continuing to test with larger files, and will update with my findings)
Jay
Jayl
I have successfully uploaded a 4h video, 5.4GB - with no problem.
Thanks for the support,
Jay
State of falcon pi cap? by K-State Fan
Today at 05:26:05 AM
Text on Matrix by JonD
September 29, 2023, 03:01:31 PM
Is the Pi 3B still supported on 7.1? by Poporacer
September 29, 2023, 12:36:58 PM
Unable to dock sub-Windows back into xLights by cmndr brain
September 28, 2023, 09:15:00 PM
FPP Ignore GPIO triggers outside show hours by robbiet
September 28, 2023, 08:39:29 AM
Can’t see F16V3 through FPP by Laser Falcon
September 27, 2023, 03:26:16 PM
All new stuff by i1uhrace
September 26, 2023, 09:57:48 PM
Unable to change color curves by cmndr brain
September 26, 2023, 05:44:08 PM
Matrix audio issue by MikeKrebs
September 25, 2023, 09:11:08 PM
Music and models out of sync by MikeKrebs
September 25, 2023, 09:08:25 PM
