Total Members: 16935
Latest: HangGlider
New This Month: 10
Total Topics: 17022
Most Online Today: 101
Guests: 79
Total: 79
Weird latency over artnet
Started by dsg123456789, April 21, 2023, 11:13:11 AM
dsg123456789
I just started setting up my system, which has an F48V4-NS connected to an SRx1-PSU. I haven't touched any switches or knobs on the boards.
I am using SK6812 RGBW LEDs. My configurations are screenshot below.
When I try to push an animation from pyartnet, I can see it's sending the sacn/e131 packets at the rate I expect. However, it takes 3-6 seconds before the frame appears on the pixels, but I expect to be able to push at least 20fps. Is something misconfigured, or is there something else I need to do? I included my basic code listing below too, just in case it's helpful.
import asyncio
import logging
from pyartnet import SacnNode
import sys
logging.basicConfig(level=logging.DEBUG)
async def main():
    i = int(sys.argv[1])
    x = int(sys.argv[2])
    # Run this code in your async function
    node = SacnNode('192.168.20.119', 5568, max_fps=30)
    node.set_output_correction(None)
    channels = []
    NUM_UNI = 3
    NUM_CHANS = int(384 * 3/4 / NUM_UNI)
    for u in range(NUM_UNI):
        universe = node.add_universe(u+1)
        for l in range(NUM_CHANS):
            channel = universe.add_channel(start = l * 4+1, width=4)
            channels.append((universe, channel))
    t = 0
    dt = 0.01
    while True:
        val = [0,0,0,0]
        val[i] = int(x * t)
        for (u,c) in channels:
            #c.add_fade(val, 100)
            c.set_values(val)
        t += dt
        if t > 1 or t < 0:
            dt = -dt
            t += dt
        # GRBW
        print(f"value is {int(x*t)}")
        await asyncio.sleep(0.2)
asyncio.run(main())
MikeKrebs
