Total Members: 16425
Latest: Bagley2001
New This Month: 18
New This Week: 3
Total Topics: 16403
Most Online Today: 91
Guests: 57
Total: 59
F4V3 controller - IP address issues
Started by Keebler, October 16, 2023, 06:46:15 AM
Keebler
So, the only way that I can get the controller to get an IP address is to hold the button at the top left corner. then it will get an IP address, but I can not do anything to set the board up - if I take pressure off the the button (top left corner).
I have FW ver 2.55 (obtained from the web interface) - is there a newer version that possible corrects this issue?
The board is new... I bought it a few years ago, forgot I had it, found it, and thought this is exactly what I need for a new location at my home... however. I am having issues...
a quick search for firmware, takes me to the F16 pages. is the F16 firmware the same as the F4? I wouldn't think so...
Firmware 2.59 is the latest public release.  F16v3 and F4v3 do not use the same file.
https://pixelcontroller.com/store/content/11-f4v3-pixel-controller
Not aware of it correcting any issue like you described.
Keebler
thank you for the link.
Ill contact David then about this issue - thank you
Keebler
So, Ive tried unsuccessfully, to update the firmware by sd card.
here are the steps I took
formatted the micro sd card (in this case a 4gb) to fat32
copied the file F4V3_2_59.fl2 to the sd card
placed the sd card (face side right) in the sd card slot
booted the board
nothing happened - went right to the default
tried it as well with the F4V3_BootloaderUpdater_v1.00.fal
expecting to see the remove sd card message
nothing
both times
the oled shows
"booting controller"
the falcon icon
then the status screen
it seems to be ignoring the sd card slot
Did you reset your F4v3 first?  Many people skip over that step, but it is important to do that.
breese
Factory Reset (Needed when updating from 2.0x )
1) Save settings to file to reload after update.
2) Power Down
3) Hold in Select button (Next to Right Button)
4) Power up while holding button. The controller should display message stating a reset is occurring.
Replacing bootloader. (These steps are only done once)
1) Place BootloaderUpdater_v1.00.fal on a MicroSD card (32GB or Smaller, formatted Fat32).
2) Place MicroSD card into controller and apply power.
3) The application will be loaded and the screen will prompt to remove sd card and power down then up.
4) Remove SD card.
5) Power Down/up
6) The application will replace bootloader.
Updating Firmware (These steps taken for each firmware update)
1) Place .fl2 file MicroSd card
2) Power Down/Up
3) The firmware will install
4) Remove card when finished and power down/up.
5) Controller will boot
At firmware 2.55 you probably do not need the "F4V3_BootloaderUpdater_v1.00.fal" file.  It is not going to hurt to update it again, but I have had it get in the way and keep the "F4V3_2_59.fl2" file from loading.  Make sure you reset the controller, and then place only the .fl2 file on the card.
Keebler
The controller completely ignores the SDCARD.
double checked the format (FAT32)
double checked the SDCARD 32gb or smaller
double checked that nothing else is on the SDCARD
double checked the SDCARD is seated properly in the slot
did we not used to have the ability to update the controller via network? I can recall updating several controllers via the network a few years back
#8
I have had them not want to take 2.59 before.  Seems like I downgraded to 2.55 first, and then upgraded to 2.59.  You might try a couple of older firmware versions like 2.55 or 2.58.  If you can get either of those installed, you should be able to upgrade to 2.59 after.
There is the Falcon Update Tool-1.0.exe, but the controller has to be functioning with a valid IP address in order to use it.  I would reach out to David and see what he has to suggest.
Store Information
