Total Members: 16932
Latest: encore
New This Month: 7
Total Topics: 17018
Most Online Today: 117
Guests: 73
Total: 74
FPP Unresponsive
Started by jem5136, November 27, 2023, 04:21:59 PM
jem5136
I'm having some issues with my next K8-B Scroller. I purchased it this summer, got it all set up and it was running perfect during testing, however, it's now freezing and becoming unresponsive between sequences. It is set up as a remote, controlled via multi sync. It's using a USB wifi adapter, static IP and DHCP DNS (same as all other FPPs being used but with a unique IP address). I'm able to navigate the UI and have complete control, even play a sequence. When the first sequence plays, the stats look normal, 100% functional, but as soon as the 2nd song starts it goes unresponsive and pixels freeze. A power cycle is required and then it does the same thing all over again.
I haven't looked at the logs yet, but any ideas what might be going on? Should I leave the gateway blank in the network? Change the DNS to 1.1.1.1 or 0.0.0.0?? The sequences are all V2 uploaded from xLights with FPP Connect. This is the only FPP i'm having issues with, the other 7 run without an issue.
I should note, hardwiring it has made no difference in performance- still becomes unresponsive after the first sequence finishes.
7.3.x has had a few issues.  From personal experience... if 7.3.0 was ever installed, you need to install a fresh image and restore from backup.  The 7.3.1 image has a few issues, so make sure to fully update after it is running.  7.3.5 has been fairly stable for me.
jem5136
As of right now everything is running 7.3.1. I'll try upgrading to 7.3.5, I'll do a fresh install and see if that does the trick.
