Total Members: 16422
Latest: geoffhoops63
New This Month: 15
Total Topics: 16402
Most Online Today: 102
Guests: 58
Total: 58
FPP 7.3 sound blaster issue
Started by Chicken, December 06, 2023, 02:54:41 AM
Chicken
Hi, it seems like every few times we reboot or restart our main show FPP it defaults back to the built in sound card on our pi 4 instead of using the sound blaster.  We had someone ask tonight why the radio was not working and we checked and it changed again back to the built in.  Anyone else seeing this?  We are running 7.3.2 on this controller.  Thanks
breese
If the transmitter is within 10 to 15 feet of the Player, it will cause interference with the USB connections on the player.
Move the transmitter away and higher than the player.....
friskybri
Is that the transmitter or the antenna.
K-State Fan
Mine has switched to the built in at least once this year.
I will try moving farther away.
#4
The Pi has reverted back to default audio after every single OS upgrade for me.  (which is different from an update)  It typically will not reboot after an OS upgrade ether... so if your Pi locks and up/doesn't reboot after updating, you should confirm your audio is still set to the Sound Blaster settings after you manually power cycle it.  In other words, when going from 7.2 to 7.3 there is a decent chance it is going to mess with the audio settings, versus 7.3.1 to 7.3.5 is less likely to change it.  Not sure that is the case every time.
Add a 5 -10 second boot delay in the fpp settings and see if that fixes the issue.  The newer Pi are booting fppd too quick sometimes before USB sound cards can be fully ready so fppd ends up reverting to the default as a fail safe.
Chicken
Quote from: CaptainMurdoch on December 06, 2023, 11:25:25 AMAdd a 5 -10 second boot delay in the fpp settings and see if that fixes the issue.  The newer Pi are booting fppd too quick sometimes before USB sound cards can be fully ready so fppd ends up reverting to the default as a fail safe.
Makes total sense.  I'll give it a try.  Thank you
