Total Members: 16905
Latest: Overwatch
New This Month: 21
New This Week: 6
Total Topics: 16993
Most Online Today: 124
Guests: 84
Total: 85
How do I connect the Distro board?
Started by szaske, January 28, 2024, 06:08:13 PM
szaske
I recently purchased a F8 Distro board v5 and since there is no instructions that come with it I thought I'd post my question here since I'm power dumb.  How do I connect the board up to my power supply?  The connector is marked GND and V.  I assume I connect the +V terminals to V, but what do I connect to GND?  I'm assuming it connects to a -V terminal, but with it labeled GND I wanted to make sure it shouldn't be connected to the ground terminal (the terminal between -V and N). Also I assume I connect the connector labeled "Fuse Control Input" to one of the 2 connectors labeled "External Fuse Control" on my v5 controller.
MikeKrebs
Ground is a common name for V-. They are synonymous for DC use. Ground isn't quite the same as V- but by common usage on DC circuits, you can assume they are the same. Definitely not the ground of the AC plug.
I don't have either board so can't definitely answer the question about the external fuse control. But by description, that is exactly what you should do.
Falcon PiCap not working on FPP 8.3.1 by Poporacer
Today at 09:41:49 AM
Cheap Amazon pixel controller by breese
Today at 04:51:12 AM
Virtual Display not working? by avarrassi
March 24, 2025, 02:29:34 PM
Interactive Mini golf using FPP? by Bwinter
March 24, 2025, 09:32:30 AM
March 22, 2025, 12:45:02 PM
March 20, 2025, 08:21:46 PM
March 18, 2025, 06:00:53 PM
March 18, 2025, 04:38:32 AM
March 16, 2025, 11:58:28 AM
March 16, 2025, 05:07:48 AM
