Total Members: 16523
Latest: Hotrodnick
New This Month: 11
New This Week: 3
Total Topics: 16547
Most Online Today: 86
Guests: 25
Total: 25
Changing FPP firmware
Started by CUC, July 18, 2024, 04:20:33 AM
CUC
I want to downgrade my FPP from V7.2 to 6.3 how do I achieve this.
Is there a reason that you want to downgrade?
7.2 is not the most current version and if you hare having issues, it was likely fixed in the newer versions.
A direct downgrade using the fppos method has not been tested and should work, but you might just have to re-image your SD card. But I HIGHLY suggest looking at your reason for downgrading before you go that route.
CUC
I want to have all of my units working on the same rev. All of the others are 6.3 and they give me no trouble. Keep getting error messages on 7.2 so bad that I am thinking of throwing unit away.
Quote from: CUC on July 18, 2024, 05:07:58 PMKeep getting error messages on 7.2 so bad that I am thinking of throwing unit away.
What are the error messages?
The developers have improved the error reporting quite a bit over the releases and yes, you might get an error on 7.5 that you didn't get on 6.3, but that isn't because there was no error on 6.3, it was that 6.3 didn't report them. They keep putting in error messages when there are common problems to help the user figure out why their FPP isn't running as they expect it to run.
Definitely give a try moving up to 7.5 first.   Dropping to 6.x is likely not a good option as xLights will likely stop supporting 6.x in the upcoming months (when 8.0 is released) so if you are using xLights to push config/sequences, you need to start getting all the units updated to the latest, not held back on 6.3.
CUC
Quote from: Poporacer on July 18, 2024, 08:41:25 PM
CUC
The message is shown below.
Abnormal conditions may cause poor performance
BBB48-string could not read pin configuration of HE123
Could not initialize output type BBB48 string. Check logs for details
Quote from: CUC on July 19, 2024, 12:01:08 AMBBB48-string could not read pin configuration of HE123
Are you using an HE123 controller?
If so, many of those boards had a bad EEPROM firmware that needs to be updated to work with the newer versions.
Quote from: CUC on July 19, 2024, 12:01:08 AMCheck logs for details
And, what did the logs say? Can you post the fppdlog? Post as an attachment.
CUC
I will try today BUT I am 81 and know very little.
breese
Well... it SHOULD be as easy as going to the Cape Info page in FPP, EEPROM Upgrade tab, and selecting the Vendor/Board/Version and hitting Upgrade.   However, Hanson doesn't apparently want to do any work at all to make it easier for his users/customers so it's going to be a bit of work.
No data lights on smart receiver by tbone321
Today at 03:56:57 PM
FPP 8.0 Released! by Santacarl
Today at 02:24:02 PM
GE iTwinkle by Hotrodnick
Today at 02:12:38 PM
New K16s by tetleytealeaf
September 10, 2024, 08:36:29 PM
Setting up FPP and Xlights to talk to PCA9685 (Servos) by Poporacer
September 10, 2024, 05:21:56 PM
Can I control 12 volt WS2811 Pixels with the PI Hat. by tbone321
September 10, 2024, 04:06:04 PM
P5 Matrix on FPP 8.0 help by cmora111
September 10, 2024, 02:27:47 PM
Falcon srx1 psu problem by Vet4Christ
September 10, 2024, 04:34:56 AM
HELP - Panels Blown or PocketScroller messed up by DaSarge
September 09, 2024, 05:03:25 PM
Lights don't work on K16 by jnealand
September 09, 2024, 07:23:53 AM
