Total Members: 16921
Latest: Arkianix
New This Month: 15
Total Topics: 17012
Most Online Today: 291
Guests: 251
Total: 253
Overlay Matrix: write more than one pixel at a time ?
Started by zaicik, August 06, 2024, 12:44:57 PM
zaicik
Looking to make "generative" scripts, I want to feed "live" data to FPP (e.g. sensor-based)
While the API will gladly give an overlay model's full contents (e.g. /api/overlays/model/:ModelName/data)  I haven't found how to feed it data other than one pixel at a time (/api/overlays/model/:ModelName/data)
While this API is practical to draw one pixel at a time from the matrix tool menu, I'm guessing there might be a more efficient route if I want to take more control...
Any tips / suggestions ? 🙏
darylc
There is no API command to achieve that today.  We would welcome a pull request for an implementation of one.
You could draw inspiration from the CopyFileToMappedBlock function in https://github.com/FalconChristmas/fpp/blob/master/src/fppmm.cpp
If the scripts are running on the same FPP instance as the models, the best bet is to mmap the data blocks from /dev/shm .   Each of the models gets a file in there of the data and you should be able to write into it directly.
zaicik
Thanks for the pointers.
I'm gonna start by fiddling with /dev/shm as per @dkulp 's recommendation, and see where it takes me.
The data blocks being accessible this way looks like an amazing opportunity by the way: on a powerful enough Pi or BB, one could probably run Processing scripts and output each frame to a matrix. The syntax is extremely simple and could be a huge level up with minimal coding abilities.
Regarding:
Quote from: darylc on August 07, 2024, 06:02:53 AMThere is no API command to achieve that today.  We would welcome a pull request for an implementation of one.
Contributing to the API is likely above my current coding abilities but let's see how much I learn along the way and I'll try my best.
niemy
Hello
@zaicik did you manage with sending data ? I try also send let say native data to the falcon and I don't know how to start ?
Generally I need send a data for scoreboard but from time to tim I would like display some GIF etc.
Also I thought about DDP protocol but I don't know if it's efficient enought.
FPP8.5 odd behaviour with usb dongle on restarts by AAH
Today at 03:53:31 AM
Cabling to the LEDs by k6ccc
April 28, 2025, 09:21:57 AM
Something changed when using FPP Connect by Poporacer
April 27, 2025, 11:09:56 PM
RPI02W won't recover from power failure by darylc
April 26, 2025, 02:30:01 AM
Macbook Pro M4 Red/Green Status Functionality On Controller Tab by allknowing2012
April 21, 2025, 07:01:13 PM
Mega tree guy lines by JonD
April 20, 2025, 10:06:56 AM
BBB SD Card max size? by megaxxl33@gmail.com
April 19, 2025, 09:36:11 PM
LYNX ZEUS 16/8/scc by edwinpeek
April 14, 2025, 05:54:16 PM
F16v5 Monitor tab not displaying any information by FireSlayer
April 10, 2025, 09:05:58 PM
LED Matrix by Dan01
April 10, 2025, 11:18:29 AM
