Total Members: 17087
Latest: Easygoing1
New This Month: 11
New This Week: 9
Total Topics: 17169
Most Online Today: 509
Guests: 93
Total: 93
Random flickering longer away from controller
Started by foremore, November 26, 2024, 07:16:47 PM
breese
Run a sequence or RGB test on your display.
While running, use a volt meter to verify voltage at the outer areas having issues.
If less then 11+ volts, you need better power injection. Possibly a supply out at those area's.
foremore
Alright this is solved!
I was overthinking when and how to connect the V- at the controller box. I connected it wrong and it generated a lot of feedback that I managed but didn't fix. Once I removed the common v- loop I created everything corrected.
I added a common v- cable right after the controller to a v- bridge to the other v- from that port and then back to the lights... after removing that single wire to the bridge and having the v- directly from the controller to the lights everything works great now.
