Total Members: 17219
Latest: Ash
New This Month: 18
New This Week: 4
Total Topics: 17305
Most Online Today: 250
Guests: 188
Total: 188
Backup SSID Preventing Connection
Started by Bwinter, December 04, 2024, 07:37:34 AM
Bwinter
My (primary) wireless setting works properly (FPP connects as it should).  However, when I simply add a backup SSID and reboot, the FPP no longer connects to my router (through the primary network).  Nor will it connect (to primary) when I delete the backup SSID.  At this point, I'm only able to connect through tethering.
The only way I can reconnect is through performing a FPP backup. complete reinstall.
I'm on a Mac, FPP 8.3.1, Pi3B+.
Quote from: Bwinter on December 04, 2024, 07:37:34 AMHowever, when I simply add a backup SSID
I have not noticed that setting before.  What do you mean by a backup SSID?
Bwinter
#2
A recent (?) update allows you to enter TWO networks—primary and backup.  The FPP will try to connect to both.
I think my current issue is actually worse though...any attempt to change/tweak the primary network settings prevents any WiFi connection (even when returned to the original setting).
So I don't think this issue is strictly related to backup network, but bombs at ANY network interface change.  I can only connect through teetering.
It takes a full reinstall to get it back in my primary network
Bwinter
This has error has been easily reproducible (with multiple different uSD cards):.
  • Format a new uSD (8-32 gb) with SD Card Formatter.  Burn FPP-v8.3-Pi.img using Balena.
  • Insert the card in a Pi 3B+, connect by tethering (as usual).
  • Perform all the normal setup activities (set location, and grow file-system).  Reboot and connect through tethering (again).
  • Enter my network/password credentials in the network section.  Reboot.
  • FPP connects to my network (using a DHCP assigned address).  At this point, everything behaves as normal/expected.
  • I go back into the network settings and tweak either the network name or password (or try to set a static IP address).  Reboot.
  • As expected, FPP doesn't connect to my network (as the wrong name/password was entered). I'm able to reconnect by tethering (192.168.8.1).
  • I then go back to the network credentials and update the network name/password (to the correct setting).  Reboot.
  • From here on out, I'm unable to reconnect my my network--only through tethering. I'm simply unable to get any connection back to my router (after multiple attempts at re-entering the network name/password and restarting).
Am I simply overlooking something crazy obvious here?  I've reformatted several different cards, and used two different Pi 3B+...all with the exact same reproducible error.
Bwinter
Now that I somewhat got things stabilized (ie never touch the network page once it's set), I'm seeing that there is a significant TIMING offset between the main (audio) and all my remotes (lights).  It only occurs on a handful of song, but it's consistently those songs through each cycle of the playlist (so it's not a router delay that's sporadic).  And even in those cases, all my remotes are in-sync (so it's not that my remotes are loosing Wi-Fi access).
Of course I've tried to reupload and power-cycle everything, with no resolve.
Bwinter
I was able to get everything back to normal and running properly.
Thanks to 7.5!
FPP MIDI plugin installed but wont trigger Playlist by MikeKrebs
January 20, 2026, 08:48:20 PM
FPP 9.5-1 causing 192-168-8-1 for most WiFi IP by Sawdust
January 20, 2026, 01:52:27 PM
pocketbeagle2 - OLA with PRU DMX output by s-light
January 20, 2026, 01:22:17 AM
Long term issue with FPP on Beagle by Sawdust
January 18, 2026, 11:50:52 PM
FPP driving P10 and also pixel outputs - several options by k6ccc
January 18, 2026, 05:49:34 PM
LoRa plugin. Is it worth pursuing in 2026 by dkulp
January 18, 2026, 05:18:50 PM
SRx4 Long Range Quad SmartReceiver by tbone321
January 13, 2026, 03:32:30 PM
Pixel Port by LedMutt
January 13, 2026, 12:57:46 AM
Peace Stake material by LedMutt
January 12, 2026, 12:15:36 AM
Forbidden Error Port 80 by darylc
January 11, 2026, 10:24:48 PM
