Total Members: 16877
Latest: jsass2@icloud.com
New This Month: 16
Total Topics: 16974
Most Online Today: 136
Guests: 35
Total: 36
FPP 8.3 on Pi 4B, can't get it to show correct date/time via NTP
Started by geeman1082, December 05, 2024, 10:58:34 AM
geeman1082
Hi All.  I'm new at this, so I'm sure I'm missing something simple.  I set up a Raspberry Pi 4B with FPP 8.3 and am able to access it via ethernet.  It has internet access (e.g., it displays the remote Git version), but it's showing a date in September.  The only message in the health check is "Your FPP system date/time is significantly different to the browser, please verify".  Same results if I leave the NTP at the default or use time.google.com.  RTC set to none, time zone set to America\Chicago by using the lookup button.
Note: the date/time isn't critical to my intended application (a stand-alone setup driving a single F16V4, repeating a sequence continuously), but it implies that I don't have something set up correctly.
My F16V4 is able to get the current time/date from time.google.com, which apparently was the default because I didn't change that.
Any suggestions?  Thanks.
If you're not having fun, lower your expectations.
There have been some NTP issues with 8.x.  I did not have any with 8.3.  The FPP device would need to have internet and working DNS to update.  What happens if you enter an IP instead of DNS name?  Try using NTP server 132.163.97.2 and see what happens.
Quote from: geeman1082 on December 05, 2024, 10:58:34 AMSame results if I leave the NTP at the default
The default and recommended setting is to leave this blank. You should only set something here in special use cases. It does take a few seconds for the FPP to update when powered up. But I have seen issues getting the correct time when the network settings were not correct (Typically the DNS Server)
geeman1082
Quote from: JonD on December 05, 2024, 11:14:36 AMThere have been some NTP issues with 8.x.  I did not have any with 8.3.  The FPP device would need to have internet and working DNS to update.  What happens if you enter an IP instead of DNS name?  Try using NTP server 132.163.97.2 and see what happens.
Thanks for the reply.  It has access to the internet, and current DNS settings are (1) my router and (2) 8.8.8.8.  Using the IP you provided did not change anything, even after a reboot.
geeman1082
Quote from: Poporacer on December 05, 2024, 11:32:56 AMThe default and recommended setting is to leave this blank. You should only set something here in special use cases. It does take a few seconds for the FPP to update when powered up. But I have seen issues getting the correct time when the network settings were not correct (Typically the DNS Server)
I understand about the default, and tried the google site as a troubleshooting step.  DNS is set to (1) my router and (2) 8.8.8.8.
FYI, I previously had the IP address and DNS set to DHCP with the same results, but I have since set static addresses because I'm going to take this setup to another location for a demo.
There are some NTP issues listed on Github yet.
If you are technical, you might be able to take a look at your ntp.conf file and see what your minsane value is.
https://falconchristmas.com/forum/index.php?topic=16907.msg135260#msg135260
No other suggestions... sorry!
geeman1082
Quote from: geeman1082 on December 05, 2024, 12:55:40 PMThanks for looking at it.
If someone else does not respond you could try re-imaging with an older version of FPP, or stopping by the xLights Zoom Room.
geeman1082
Update:  It started working.  I've made several changes based on the above suggestions and things I've found online, so I can't be 100% certain regarding exactly what fixed it (yes, I know, that's not good troubleshooting practice, but I was getting frustrated and lapsed into thrashing), but I believe it was manually changing the DNS settings from what I listed above to (1) 8.8.8.8 and (2) 8.8.4.4, while returning everything else to defaults.
Thanks for the replies.
SRx1 v5.00 Smart Receiver showing as Pre V5 Receiver in F48V5 by alwomack
Today at 07:52:54 PM
stopping a playlist in fpp with pi gpio pins by darylc
February 15, 2025, 02:21:43 PM
xlights controller config by MikeKrebs
February 14, 2025, 09:35:16 PM
February 14, 2025, 08:03:32 AM
K2-Pi-Servo by breese
