Total Members: 17115
Latest: dave.sierck@gmail.com
New This Month: 39
New This Week: 6
New Today: 4
Total Topics: 17190
Most Online Today: 213
Guests: 63
Total: 64
Copy SD to NVME - new NVME fails to boot properly
Started by ericmolnar, September 06, 2025, 01:40:38 PM
ericmolnar
Basically, I've tried a number of ways to get an NVME drive to work w/ RPi5.  I've used the built-in copy to NVME (both the fresh install and copy everything), used the RPi imager software, different NVME cars, etc....nothing seems to work.
The files/image are written to the NVME drive, but when I shutdown, remove the SD card, and then start back up, the webfront end is not accessible.  It looks like the Apache server is not running as this is the message:
Service Unavailable
The server is temporarily unable to service your request due to maintenance downtime or capacity problems. Please try again later.
Apache Server at 192.168.88.193 Port 80
I can login, access the command line, view directories, etc.
When booting up with a display attached, there were some error messages about services "failing to start" (attached screen shot):
atd.service
php8.2-fpm.service
exim4.service
Thinking maybe some background php/Apache services aren't running on boot from NVME only.  Again SD card only is fine...or SD card w/ NVME as the SD card becomes the boot device.  This is running 9.1-3.
Any help would be greatly appreciated!
ericmolnar
ok...I was able to get this to work in an funky way.  Basically, cloned the image of FPP from an SD card to the NVME drive, then edited the cmdline.txt  so that the NVME drive would boot (vs SD card).  After cloning the image to NVME, also had to extend the partition.  A lot of chatgpt help there...
I'm probably not doing something right but after spending so much time trying options, watching videos, etc. I don't know why I couldn't get the NVME to boot right...whether it was no boot at all or boot but with services like Apache not quite working.
breese
With my NVME I had the same issue.
With mine i had to bring up the rasp-config application and set the boot for the NVME.
I documented in on the github pages for FPP
https://github.com/FalconChristmas/fpp/issues/2094
I have had no issues with it since doing it this way.
UDP output set to send data to myself error by mrgimmeone
November 16, 2025, 09:05:17 PM
Can't connect to Falcon F16v5 by Poporacer
November 16, 2025, 03:13:07 PM
Setting on a F48V4 blue by LOUIS
November 16, 2025, 03:52:27 AM
Video on Xligths by LOUIS
November 15, 2025, 06:47:46 PM
K8-B not working with SRx2 Differential smart receiver. by allknowing2012
November 15, 2025, 06:06:06 PM
P5 Matrix: image corrupt only when playing from playlist. by warsome
November 13, 2025, 10:53:00 PM
Falcon F16v4 - WS2811 LEDs - One LED is always red by torfkop
November 13, 2025, 12:28:03 AM
Freeze Up by MikeKrebs
November 12, 2025, 08:02:15 PM
Readout realtime pixel status over HTTP or websocket by efiten
November 12, 2025, 08:03:55 AM
virtual matrix goes out after 3.20 mins by mrgimmeone
November 12, 2025, 06:07:23 AM
