Total Members: 17115
Latest: dave.sierck@gmail.com
New This Month: 39
New This Week: 6
New Today: 4
Total Topics: 17190
Most Online Today: 213
Guests: 58
Total: 59
Si4713/Vast V-FMT212R and FPP 9.1
Started by lxkev, September 14, 2025, 03:59:18 AM
lxkev
Well
I've not done a display for two years. So I thought might as well update to 9.1 and then i discovered it breaks the SI4713 plug in. Does anybody know if there any plans to get this working with 9.1 or should i try and role back my fpp/reinstall fpp 84713/Vast V-FMT212R
Did you try uninstalling and reinstalling the Plugin? There have been several people that have reported it working correctly.
allknowing2012
If this is the guy who came into zoom room - the issue was a bad channel choice on the transmitter.
lxkev
Tried re-install i still get an error. Wasnt me on the zoom
make: *** [Makefile:33: src/FPPVastFM.o] Error 1
{"Status":"Error","Message":"Could not properly install plugin"}
lxkev
Anybody got any fixes? Does it work with 9.2?
JSpo
#5
Isn't working with 9.2 either on a Raspberry Pi 4, getting the same error during installation.  Even tried re-flashing the SD with the 9.2 image; no luck.  I am in desperate need for this plugin as well.
Version Info
FPP Version:   9.2
Platform:   Raspberry Pi (Pi 4)
FPP OS Build:   v2025-09
OS Version:   Raspbian GNU/Linux 12 (bookworm)
breese
While I do not use this plugin, I did install it on my FPP v9.2 on a Pi5.
Installed perfect with no errors.
JSpo
lxkev, I created a Band-Aid fix for those having the PinCapabilities error.  Paste the below link into the top of the FPP Plugins page.  A new "--FIX--" version will appear at the top of the list.  Installing this one should get us working for now on version 9.2.  I tested it last night and worked great.
https://github.com/jasonspo/fpp-vastfmt-test/blob/master/pluginInfo.json
lxkev
#9
Hi Jspo
Thanks for looking into it. I'm still getting an error Warning ID: 5 - Could not load plugin fpp-vastfmt-test, i am running 9.2. I uninstalled the original and tried this. Tried a few uninstalls/installs and get the same error.
PI4
breese
Go into Content Setup / Logs
Without clicking on any log file, Click on Zip, download it and upload the zip file here.
breese
Looking thru your logs a few things come to mind.
1) Remote Falcon has multiple errors in the logs
2) Vast also and seems it could not create the needed directory.
3) Seems you did an in-place upgrade from 7.3 to 9.1
Under status control / FPP Backup, make a backup of your current settings.
Then with everything I can see and understand, I would recommend imaging a new SD card with 9.2 and configure it.
lxkev
#13
Hi,
So reinstalled FPP 9.2 from the pi imager software, installed the plugin fix and still get the error.
Have uploaded a new log file to the same drive,
Will try and brand new sd card tommrow
lxkev
did an update to the latest build and the original seem to work
UDP output set to send data to myself error by mrgimmeone
November 16, 2025, 09:05:17 PM
Can't connect to Falcon F16v5 by Poporacer
November 16, 2025, 03:13:07 PM
Setting on a F48V4 blue by LOUIS
November 16, 2025, 03:52:27 AM
Video on Xligths by LOUIS
November 15, 2025, 06:47:46 PM
K8-B not working with SRx2 Differential smart receiver. by allknowing2012
November 15, 2025, 06:06:06 PM
P5 Matrix: image corrupt only when playing from playlist. by warsome
November 13, 2025, 10:53:00 PM
Falcon F16v4 - WS2811 LEDs - One LED is always red by torfkop
November 13, 2025, 12:28:03 AM
Freeze Up by MikeKrebs
November 12, 2025, 08:02:15 PM
Readout realtime pixel status over HTTP or websocket by efiten
November 12, 2025, 08:03:55 AM
virtual matrix goes out after 3.20 mins by mrgimmeone
November 12, 2025, 06:07:23 AM
