Total Members: 17233
Latest: Justmike
New This Month: 3
Total Topics: 17321
Most Online Today: 1283
Most Online Ever: 8375
Guests: 327
Total: 327
FPP driving P10 and also pixel outputs - several options
Started by k6ccc, January 16, 2026, 03:23:49 PM
Just a sanity check.  I am making some changes to my show for 2026.  For 2025, I ran each my P5 and P10 Tune To matrices from a PocketBeagle with SMPTE Time code from my LOR Show Player.  It worked well.  For 2026 the P10 TuneTo matrix will be split in two and a new larger P10 TuneTo matrix will be built that will use a RasPi with a ColorLight card.
For 2026, I am re-arranging things a bit and expect to have two 1 x 6 P10 matrixes "Firesticks" with a pixel star on top.  I expect to have the sequences loaded on the PocketBeagles with PocketScrollers and again use Time Code.  What I would like to do is have the PocketBeagles also drive (directly or indirectly) the pixel stars.  The original plan was to use a F4v3 driving Diff. Receiver boards driving the stars.  However if I can have the star driven from the PocketBeagle, that would simplify the wiring quite a bit - that would leave each Firestick with only power and one network connection for the Time Code.
So, first of all, if I have a PocketBeagle running FPP with a PocketScroller driving a P10 matrix, can I also drive three strings (270 pixels) of pixels directly from the PocketBeagle, or get the PocketBeagle to drive a Diff. Receiver board (I have plenty of the white ones in stock), or lastly output E1.31 to a pixel controller (likely the aforementioned F4v3).  Part two of this is will the PocketBeagle have the horsepower to do this?
Currently, the only "cape" that can output to both Panels and pixel strings is the K8-B-Scroller.  While the PocketBeagle could do it, there isn't any code in place for that use case.
Quote from: dkulp on January 18, 2026, 05:10:20 PMCurrently, the only "cape" that can output to both Panels and pixel strings is the K8-B-Scroller.  While the PocketBeagle could do it, there isn't any code in place for that use case.
Thanks.  That's an interesting option I was not aware of.  I was aiming to try to use the PocketBeagles that I already have, but this becomes a very clean option.  The plan is that the two firesticks will be between arches 1 & 2 and 5 & 6.  With 8 pixel string outputs, I could easily drive the three strings on the star, and three of the arches from each K8-B-Scroller.  One board does it all.  I would need both 5V and 12V power (the arches and most likely the stars are 12V, and of course the P10 panels are 5V), but that's not really a problem for me...
F16v3 Expansion bad resistors by 2Couyon
March 13, 2026, 04:03:59 PM
HUB75 P4 1/10 Matrix by k6ccc
March 13, 2026, 08:45:44 AM
Retrofit and Simple Message Generation Software Recommendations by StickyWicket
March 11, 2026, 02:06:58 PM
FPP 9.3 Released! by lrhorer
February 25, 2026, 09:28:30 PM
P2.4 128X64 32S (ICND2153/TC7262) by darylc
February 24, 2026, 09:29:31 PM
Projector Controler by djmc2002
February 24, 2026, 05:30:55 PM
Trying to get lights working on one port, no luck by gthoman
February 23, 2026, 07:59:22 PM
FPP 9.5 by alman4511
February 16, 2026, 09:53:32 AM
