Total Members: 16851
Latest: mikebrowder
New This Month: 29
Total Topics: 16955
Most Online Today: 92
Members: 4
Guests: 44
Total: 48
Projector Control Plugin
Started by Bshaver, January 14, 2015, 07:31:55 AM
rmonty
Would it be possible to get the following commands added for a Domino Sim2 Projector?
     Array("NAME" => "Domino SIM2",
                "ON" => "\xBE\xEF\x02\x06\x00\x6B\xE6\x52\x01\x00\x00\x00\x00",
                "OFF" => "\xBE\xEF\x02\x06\x00\x51\xE4\x48\x01\x00\x00\x00\x00",
                "BAUD_RATE" => "19200",
                "CHAR_BITS" => "8",
                "STOP_BITS" => "1",
                "PARITY" => "none"
I can provide the whole manual if needed, but these are really the only commands needed.
Thanks,
Ryan
Splork
Good evening,
I am trying to turn on and off the Optoma ZH406ST projector using PJLINK. I believe I have everything setup properly and have gone in to putty, changed the permissions of the executables to be completely open and tried to run the on and off scripts. I can't seem to get either to work.
I am attaching logs(link) of the plugin and failures in hopes that someone may have an idea of what is going on?
Falcon Projector Plugin
Mharnish
Hey Ben,
Can you add the NEC PE456USL projector.  I have tried all of the listed NEC projectors and no luck.  I will be using it over Ethernet and not Serial Cable
https://www.sharp-nec-displays.com/dl/en/pj_manual/pe506ul.html
Function Code Data
POWER ON 02H 00H 00H 00H 00H 02H
POWER OFF 02H 01H 00H 00H 00H 03H
INPUT SELECT COMPUTER 02H 03H 00H 00H 02H 01H 01H 09H
INPUT SELECT HDMI1 02H 03H 00H 00H 02H 01H 1AH 22H
INPUT SELECT HDMI2 02H 03H 00H 00H 02H 01H 1BH 23H
INPUT SELECT USB-A 02H 03H 00H 00H 02H 01H 1FH 27H
INPUT SELECT LAN 02H 03H 00H 00H 02H 01H 20H 28H
PICTURE MUTE ON 02H 10H 00H 00H 00H 12H
PICTURE MUTE OFF 02H 11H 00H 00H 00H 13H
SOUND MUTE ON 02H 12H 00H 00H 00H 14H
SOUND MUTE OFF 02H 13H 00H 00H 00H 15H
Thanks,
Mark
radiomarsh
New install of FPP 8.3 with the OS update. When I SSH following the instructions i get a "can't find CPAN" error. Is there a fix for this?
Thanks,
Marshall
MikeKrebs
Tiny bug by lrhorer
Today at 01:40:41 PM
Question about /home/fpp/media/config/interface.wlan0 by lrhorer
Today at 01:33:39 PM
No Fuses and No Expansion Port by JonD
Today at 10:42:42 AM
Swapped PiCap V1 with V2 - Pixels will not light in test by twseeman
Today at 10:17:24 AM
FPP Connection Question by JonD
January 20, 2025, 03:50:30 PM
Does the Falcon PiCap v2 support Renard Output? by dakingus
January 20, 2025, 09:17:28 AM
F48 v1 & F16v5 by Mark_M
January 19, 2025, 09:34:10 PM
FPP 8.4 released! by lrhorer
January 19, 2025, 11:30:42 AM
K2-Pi-Servo by breese
January 17, 2025, 01:47:06 PM
January 14, 2025, 05:54:32 PM
