Total Members: 15492
Latest: Robnation13
New This Month: 5
New This Week: 28
New Today: 5
Total Topics: 15585
Most Online Today: 66
Members: 5
Guests: 28
Total: 33
Power Distribution with Distro Board
Started by tmarshall, September 30, 2017, 10:22:29 AM
tmarshall
I was wondering what the general consensus is for wiring long pixel strings using a power distro board for power injection. Do you connect the positives between each string, or do you only connect the data and ground between strings?
I have done it both ways, and both ways have seemed to work. But, it seems to me that if you connect all of the positive wires between strings and you blow one of the fuses, the other fused power points will draw more power to compensate, and you may likely have a cascade effect and pop multiple if not all of the fuses in the distro board.
Most of the Power Injection posts I have read usually have one large fuse for all the strings on a given channel, but that would be too much power per distro board output.
What are your recommendations?
See diagram for clarification. (Diagram does not show ground from controller, but It would be connected in as well)
JonB256
Your reason for not connecting Positives is a good one.
The other reason frequently given is that the voltage regulation in different power supplies may begin to fluctuate when they sense a voltage change from each other. It could cause weird voltage oscillations and should be avoided.
So, the V- (DC ground) should be tied together. The V+ should not.
tmarshall
Quote from: JonB256 on September 30, 2017, 11:05:00 AM
Yeah, i know about the issues associated with cross connecting power supply positives. I this case, I am only using one power supply to drive about 400 pixels
sklankowski
Had this same question when connecting two string together.  We needed to insert power from the end of string one to provide enough power reduce yellowing, and had about 2 meters of light to go on string two.  As long as the lights are on the same transformer, but can understand the cascade effect of blowing fuses.  A risk in the design versus capabilities of setup, IMO.
Today at 05:36:26 AM
Today at 05:27:12 AM
Today at 05:03:25 AM
Today at 04:15:05 AM
Pi zero 2w by Sawdust
Today at 12:25:33 AM
I'm Stumped by saleencb
Standalone Mode - limitations? by darylc
November 30, 2022, 09:21:04 PM
November 30, 2022, 05:21:55 PM
